DAZ3d Not fully showing dropdown menu
Hello,
Im using DAZ3d Windows 7
if you can see Image below, the tools in upper right corner will not display proper. If i select an item the proper dropdown window will appear, Yet my Zoom, Pan etc. will not as you see.
If there is anything else you need from my Speccy Screen Grab please ask,
thank you
It's probably a limitation of the Intel GPU - you could try checking for an updated driiver to see if that helps.
