DAZ Install Manager Update Error
I went ahead and tried to run the Install Manager update that popped up on my screen when I opened DIM, but it ran into an error and now I can't install it at all. I can't access it. I get an error message that it couldn't install, and if I try to run it, I get an "unknown error" message, so it won't open at all. Did I do something crazy, or is there a glitch in the update? I now no longer have DIM, so I will have to manually installl anything new.
  • melaniemelanie Posts: 806
    Oops, looks like the whole screen shot didn't show.
    I'm really muddled here. You just need to click on the image to get all of it.
  • tophandtophand Posts: 134
    having the same problem
  • What security software are you running? This seems to be affecting a number of people, but not everyone, so it seems likely there is some cause beyond the base OS.
  • MechavenMechaven Posts: 76
    edited August 2017
    I had the same problem. If you notice that 1 at the end of the DIM (DAZ3DIM1) I found if I removed the 1 it went ahead and installed. I had numerous problems after that though with installing the latest version of Studio 4.9.
    Post edited by Mechaven on
  • MelanieLMelanieL Posts: 7,763
    Maybe your download was corrupted on the way down? Have you tried downloading the new version from your Product Library (under "Install Manager Win") to get a fresh version and try running that exe? I've had a couple of problems in the past with DIM trying to update itself so I always go the manual download method now (and run while DIM is not running).
  • fastbike1fastbike1 Posts: 4,079
    The DIM update installed flawlessly for me today.
    Thank you all, for your help. I downloaded the file from the Product Library and I deleted the 1 at the end of the file name. It worked! I now have my DIM back! It takes a village, doesn't it? All of you are great!
