Tutorial on getting morphs to dial with body rotation?
Zev0
I'm interested to know how this is done. The muscle flex set was a good example of morphs dialing according to body part rotation. Is there a tutorial on this?
It was done with the property editor, I would think. There's some older tutorials about the property editor here, but they're more about general usage for the editor. This one is just about reverse deformations using Morph Loader, but I seem to remember a part of it that focused on a JCM, which is what you're talking about. Hopefully one of them will help you.
How to do JCMs
http://www.sharecg.com/v/61711/browse/3/PDF-Tutorial/JCM-in-Pictures
Cool. That looks like the answer I was looking for. Thanks.
Hmmm. What if it is a morph that spans across 3 body parts? IE the abdomen, hip and pelvis? How would you solve that? Load the same morph for all 3 parts? It will be difficult to calculate each one to dial perfectly the same with 3 parts at different bend values. Or do you just add it to one instead of all three?
If you are using DS you can load all parts as a single step (and Genesis has geometry on the root only in any event). In Poser you can create a master morph slider on the body to control sub morphs, though with the base application you will need to load the morph for each part one at a time. If you use ERC to link to the root control you only need to do it once.
Cool I'm using daz.. And how do you create a master dial to turn all auto dial morphs on or off. Like the flexion muscle set?
The flexing morphs all get multiplied by the Flexion morph - so when it's zero so are they, regardless of the state of their other controllers (the actual bends).
Makes sense, but how do you set that up? I got all my independant morphs to flex, but all thats left is a master dial, to switch them all on or off.
If you are working in DAZ Studio, just add the Flexion morph as a controller to the various morphs ( drag the Flexion morph into the Controllers list for the flex morph in question), then change the ERC type to Multiply (with the Flexion morph selected under Controllers, Click ERC Type and select Multiply).
Perfect Thanks:)
Good stuff here... there should be a video tutorial for all this ... I'd pay for that! I'm more of a visual learner! Thanks for the info though! I'll get my head around it hopefully!
Hi Kerya
Did you remove or move your tutorial? I'm getting error pages saying it's not there anymore!
Hi Kerya
I am afraid it wasn't mine - I just linked to it.
It was pinin's. And looking for pinin at sharecg shows me he/she removed everything from his/her portfolio there.
Edited to add homepage and email adress:
http://poser-outerzone.com/meshes.htm
It was pinin's. And looking for pinin at sharecg shows me he/she removed nearly everything from his/her portfolio there.
http://www.sharecg.org/pf/full_uploads.php?pf_user_name=pinin&division_id=11&s=rd&pn=1
Thanks much. I've sent her an email! Fingers crossed that I can get my mitts on that tutorial! :-)
