How to do a version check
TSasha Smith
I want to know which version I have installed? Also if I used the pro serial number or the regular number?
i must have put it in but I cannot remember doing so. Not a big deal as I sometimes forget things, I think.
Top of the screen ,. Left hand corner ,. there's a little triangle (old Daz3D logo)
click this to open a pop out menu,. then select "About Carrarra",. that should open the Splash screen where your version number is displayed at the bottom
Okay thanks! Will check it out
if youve d/l within the last 4 years yoo haz the latest
I wanted to know if I got trial, regular or pro
The serial number will either start xxxxPRO- or xxxxSTD- You can see it in the splash screen as Carrara starts. That'll tell you what your licence is for (if you bought Pro, you should have both licenses in your account, under Serial Numbers)
I have both in my account so does that mean I bought pro? I think I usually get the pro version of Carrara. I remember when Carrara 5 was like almost five hundred which was a big deal for me to buy.
Yes.
The pro licence activates the pro features (there's only one executable 64 bit and one executable 32bit)
https://www.daz3d.com/forums/discussion/154456/stupid-question-32-bit-version-of-carrara
I forgot that. Oops
