New Morph Group? (like:Generel, Actor, Display, Hidden, Morph...)
Hi guys,
i createt some morphs and want to change the path. I dont like the Morph Loader path. I want a new group under "Morphs". But how can i do it. I now how to change the path from morph loader to actor or other groups, but i want a new group. Hope someone can help me there
Great
K4YT0
    edited August 2017
    If you hope to make new path, (group) for parameter, input path direct in the path section not use drop down menu
    (once you make the parameter for new path, after that you can choose path fro 2nd parameters. if you remove all parameter from path, it have gone away automatic from selection, and ds delete the group.
    eg input "morph" , it generate new "morph" path. then click OK(Accept)
    of course, you can add sub group path, from default one, same manner. eg input General/mymorphs  etc.
    Post edited by kitakoredaz on
  • ah perfect thank you for the fast answer. Your are a great help thank you very much.
