V4.2 installation for Poser 2012 fails
jesuschoyjesuschoy Posts: 57
edited March 2013 in Poser Discussion
The installer of V4.2 for Poser 2012 fails. Don't recognize the directory where is PoserPro.exe.
What can I do? See figure.
Post edited by jesuschoy on
  • info_7ab70978f3info_7ab70978f3 Posts: 78
    edited March 2013
    Use your explorer and nav to the folder your poser pro 2012 content folder is in
    Make a "Victoria 4" folder in that folder create a new text file rename this file Poser.exe acknowledge the warning and
    run the install to this new arrangement then add the library in PP2012
    Post edited by info_7ab70978f3 on
  • fixmypcmikefixmypcmike Posts: 19,709
    Do not install to Program Files -- that error message hasn't applied since Poser 7. Either create a dummy file named Poser.exe in the folder containing your real runtime (the default is in Documents), or choose "DAZ Studio" as the target application -- it'll install the same files, but won't check for the existence of Poser.exe.
