How to smooth out a simple object
I was using an apple in a render and noticed prominent marks from underying polygons. I've attached several pics.  Have tried increasing the Model and Render level - but that only makes the lines more prominent.  Tried tesselating; tried subdividing; tried smoothing all angles on the apple's body - and none of those are helping.
Any suggestions? (please see attached images)
  • DiomedeDiomede Posts: 15,398
    Can you show the mesh?  Hard to tell from the textured surface.
    Worst case scenario, use the displacement brush in the vertex modeler.  It has a "smooth" setting.
    1592 x 949 - 99K
  • 3DAGE3DAGE Posts: 3,311
    Looks like you've got some creased edges and triangulation going on
    Select the object and go to Model / Smooth edges
    then add your levels of smooth.
