SOLVED - Exporting light cones from Carrara for After Effects
Mosk the ScribeMosk the Scribe Posts: 892
edited August 2017 in Carrara Discussion
I made a simple animation that included spot lights with light cones turned on to create a volumetric light effect.
I want to be able to adjust those light cones independently in After Effects.
Is there a specific 'pass' I can toggle on in the multi-render pass options (when exporting as .rpf seqence) tha would just capture the lights?
(I can pretty much isoloate it with ID Matte in After Effects) - but ideally would have render separately from Carrara
Post edited by Mosk the Scribe on
  • DartanbeckDartanbeck Posts: 21,988
    Not sure. It's a volumetric lighting effect that is often best kept subtle, which still ends up being quite noticeable in the end.
    I don't use Adobe, but have both Howler and HitFilm. In Howler I have varius filters for making animated lighting effects, and in HitFilm (since I still use Express - Pro comes with all of this) I bought the Atmospheric Lighting upgrade pack, which has really nice automated lighting effects that can be altered physically with masks and such.
  • DesertDudeDesertDude Posts: 1,239
    Would 'Volume Effect' from the multipass pane in the Render Room be helpful?
    1302 x 508 - 133K
    235 x 202 - 14K
  • Not sure how I missed it, but yes- that's what I was looking for.  Thanks.
