Multiple instances of genesis found
sriesch
I've been ignoring this for a very long time, but hoping somebody might know how I should go about cleaning this up, if it's an easy fix worth the effort. Whenever I load the base default untextured Genesis, I get the following message, and have to click one at random to continue. Any idea why it thinks there's two? I do note that one seems to have an uppercase and one has a lowercase path. v4.8 if it matters.
Post edited by sriesch on
I don't get the custom action ,but it yells about duplicate IDs when I load Genesis ....so I'm no help
The custom action is probably because it's a custom menu item to run it. Which is a good point, I DON'T get the error message when I double-click on the content library thumbnail for the same thing, only when I select it through the menu, which is probably a clue.
It's probably the capitalization. Something in the settings of your action.
You can fix that by following the Log File. I once had that issue and in the Log File, it told me what the duplicate(s) were (and where) and by deleting them, it cleared that up.
Thank you I'll try that!!
From Window > Workspace > Customize, then right-clicking on the menu item and selecting "Edit Custom Action" from the mouse menu, I get the following. I tried changing the "Genesis Starter Essentials" part of the path name to uppercase to match the real folder just for kicks, although that had no effect. Otherwise it's just the code that gets created automatically when you create a custom action. Other custom actions don't have this issue, just this one does.
