Greek Boat
gcshepgcshep Posts: 31
Help needed please I have a Greek boat with the oars attached plus sail I have tried using the the convert tool but it just converts them all together I have attached two images of a before and after.
Best Regards
George
  • fixmypcmikefixmypcmike Posts: 19,707
    What is it that you're trying to do?
  • gcshepgcshep Posts: 31
    If possible make all the oars and sail individual props I know how to convert but first I need to un-parent and this is were I am having a problem.
  • Richard HaseltineRichard Haseltine Posts: 109,065
    Try enabling Show Hidden Proeprties in the Parameters pane option menu (the lined button in the top corner, or right-click the tab) - you may find you can then translate them separately.
    Failing that, you would need to use the Geometry Editor tool to select each in turn (most simply by using the + next to the name in the Tool Settings pane), right-click Geometry Visibility>Hide Unselected, right-click Geometry Editing>Delete Hidden, save as a prop (File>Save as>Support Assets>Figure prop Asset), then reload the ship and repeat for the next part.
    Thank you Richard the second part of your suggestion worked just fine.
    Best Regards
    George
    yes
