how do I zero the origin of an object in DS4.5?
StratDragonStratDragon Posts: 3,278
I tried to follow a youtube video on this, I don't see the joint editor in my tools menu. Is this a separate install somewhere?
  • MedzinMedzin Posts: 337
    It's in the tools menu, Alt shift J will activate
    You can also go to Posing | Shaping tab and select it under tool settings
  • wancowwancow Posts: 2,708
    do you want to make the origin of the object an XYZ value of Zero? If it is not a figure, but is instead a prop with no moving parts, I would strongly suggest simply placing it exactly where you want it to be, exporting to OBJ, and re-importing it. That is the simplest way. Otherwise, you need to use the joint editor.
  • macleanmaclean Posts: 2,438
    Actually, the simplest way is to use the free Move Origin utility. You can find it on the free DS scripts page.
    http://forumarchive.daz3d.com/viewtopic.php?t=42376
    mac
  • StratDragonStratDragon Posts: 3,278
    Maclean that was the link i was looking for, unfortunately only 4 shared has it and they wont let you download it without signing up by validating an email, which is more hoops of file from a webhost that is desperate to install malware on my box one way or another.
    I think I may have that version at home if the DS3 version works in DS4. if not does anyone know if Delta X15 is still around?
