DAZ Studio PARAMETERS Panel Information
Fauvist
in The Commons
I have hundreds of sliders. Is there any way to find out what product each of them are from? Can I click something on the parameters panel and it will tell me, for example, Freak 4 Creature Expansion?
Thanks!
Nope.
Some of the data that could point out where you'd find the files for the parameters is accessible via the scripting API, and clever application (or maybe not clever) of the same will actually return the full path to file, but there's nothing in the UI or userfacing tools that does that. At least nothing I've ever seen, and I've looked, it would be useful to know.
The best one can hope for is that the vendor keyed that data into the property group, somewhere. Which doesn't happen often. Usuaully, however, you can ust the property's name (which is not the label you see, but name in the settings for the property) to search the morph folder. While the name does not have to match the file name, daz generally creates morph such that the names and file names do match. So, an overwhelming majority of the time, you should be able to find the product folder this way, and the name of that folder might give you a clue as to what product a morph came from. Maybe.
The thing about it, many of these things are user facing in the authoring tools, and there's no enforced standard for how these things should be done. Also, someone might decide at the last minute to change the name from Product A to Chemical X and actually get through the whole process with all the files saying Product A whole the marketing, promos and installers say Chemical X
