Query about grey blocks /figures
Hi all, not really new been around since 2008, re-learning my way around things again
I installed the  dim version 1.1.0.67, ( previous one was working ok,a few slight hiccups)
the one above says it has downloaded and installed figures that I have checked the box on download and installation,
I open up daz studio pro version 4.9.4.117 and they are not installed, they are greyed out but daz managers says they are installed
the other strange thing is when I load a figure doesnt matter which one it is, I go to the translation tools, or shaping/posing or any other on the panel
and this happens, attachment below,
the only thing I have changed is  I installed the newer  dim, and installed a few figures I bought this morning from daz
has someone else come across this?
not a troll/robot/ etc I just never posted  much at all, angel
cheers
  • kaotkblisskaotkbliss Posts: 2,914
    DS can't find the geometry for those objects (They may be installed, but not where DS expects them to be. Perhaps they were moved or deleted)
  • Richard HaseltineRichard Haseltine Posts: 108,441
    edited July 2017
    Please don't resize your screenshots - it makes them hard or impossible to read.
    Did you not get an error on loading the content?
    Edit: rereading your post - do you mean it turns to blocks while posing, and then goes back to normal on releaseing the mouse? If so, you need to chnage the During Manipulation draw setting in the Draw Settings pane.
  • dbeezdbeez Posts: 7
    Thanks for replying kaotkbliss, that wasnt the problem though
    cheers
    Sorry about the attachment, I though they had to be under a certain size, I'll remember that for next time,
     on reflection I should have explained it a bit more, it was late though
    but Richard you nailed it, thank you so much!!
    cheers
