Directory Path for installing 3rd party content??
What is the directory path to use to make sure my custom content/ all of DAZ content shows up in "smart content" tab so I dont have to go delving into all the files through the DAZ3D LIbrary pull down menus?
  • BeeMKayBeeMKay Posts: 7,019
    You'd have to insert metadata into the database. There's a submenue point in the "Maintain DB" that inserts existing metatadata, Process Metadata Queue, if I'm not mistaklen. If the content doesn't come with metadata, then you'll have to manually create it for each item to make it show up in Smart Content.
  • myutogarumyutogaru Posts: 60
    Is there a tut on making metadata? Thank you for your help, I will try that.
    Just FYI I'm still having problems and don't have my custom content in daz if someone could hep thatd be great
  • fixmypcmikefixmypcmike Posts: 19,705
    Does it show up in Content Library > Daz Studio Formats or Content Library > Poser Formats?
