outoftouch Palm Bikini - Micro pressure morphs
Rod Wise DriggoRod Wise Driggo Posts: 2,334
edited July 2017 in The Commons
OK, OK, confess - I probably will buy another digital bikini. Not that I already have lots of them. Just can't help ;-)
Anyhow. Seeing the promos of the palm bikini and the additional textures by ShanasSoulmate I wonder how the micro pressure morphs might work. I guess there are two morph dials for top and panties. Now as the panties contain that extra strap, it might look weird once a texture from ShanasSoulmate is applied which does away with that extra strap. So question is: Are there maybe already two micro pressure morphs (one for the base panty and one for the extra strap) or if not, could that be changed in an update (if outoftouch reads this)?
I have to say I have a weak spot for all those morphs which simulate cloth pressure and tend to collect them to also use them on other cloth if they fit. Now not having that extra strap micro pressure included by default might make the whole thing much more versatile.
Post edited by Rod Wise Driggo on
  • nicsttnicstt Posts: 11,715
    Can the pressume morph amounts be changed?
    Often they look too much in the promos; most of Daz's figures are slim (yeh I know, shocker) and there is much less pressure in those instances. I also feel that there is not enough geometry to properly model the indentation morphs. Are you finding that when using them?
  • Rod Wise DriggoRod Wise Driggo Posts: 2,334
    Well I have some outfits from outoftouch with such morphs, some from the3Dwizard (who has also a standalone product for such morphs which I can only recommend) and some from Blue Rabbit. All offer those morphs as dials so you can easily change the amount of pressure applied.
    The problem with this new outfit is that apparently (from the product description) there are two morphs for the upper and lower part. Now from the promos the bottom morph seems to include pressure for that extra strap on the panties. But as some additional textures leave that strap out, it might look strange once the morph is applied. Thus my question whether the bottom morph (if it is just one) may be split into two.
