How to load morph on specific part
Hello,
Thank you for reading.
I try to use Morph Loader Pro for creating body part squish.
I created an own character and then use the character for a base to creating squish morph.
I loaded morph successfully.
But, It applies whole body morph.
I'd like to apply the morph only on the specific body part.
How should I do?
Thank you for your help.
Attach files.
  1. My character (normal).
  2. Applied the morph 100% (Applied my character whole body morph).
  3. Morph which I created.
Post edited by alexandersmith on
  • TottallouTottallou Posts: 555
    edited July 2017
    You need to import the morph with Morph Loader Pro with Reverse Deformation as Yes
    That way you only get your changes applied to the character
    1116 x 572 - 72K
    Post edited by Tottallou on
  • Hello Tottalou,
    Thanks a lot!
    My problem is solved!
    Thank you so so much!
