Maybe a stupid question: Adding a prop to a prop with a morph and make it following the morph, too.
cosmo71cosmo71 Posts: 3,609
Hello, I have a question. I have a truncheon prob with a retract morph and I want to add another prop to that prop and make it follwing the morph, too. Is it possible? Have a look at the image, that shows hopefully what I mean.
  • Richard HaseltineRichard Haseltine Posts: 108,079
    Try selecting a polygon on the part you want to follow with the Geometry Editor tool, then right-click Geometry Assignment>Create Rigid Follow Node from selected, right-click, Greometry Assignment>Create Rigid Follow node referecnes group. Now parent the item you want to follow to the rigid follow node, a child of the prop.
  • cosmo71cosmo71 Posts: 3,609
    Many Many thanks Richard, that works, but I just need to select a polygon and create a rigid follow node the thing with the node refences group I don`t need so it seems. And this was so helpfull I now have a solution for so many things. That was really helpfull.
