Couple of issues
First issue:
Daz 4.9 not reading metadata from PowerLoader for V4 etc. Muscle Morphs are only ones to load. (see attachment)
Second issue:
V4 Ethnic Faces not loading in Daz 4.9
Third issue:
Problem is in Poser 10 with not being able to use Morphs to open and close eyes nor brow movements on V4 etc. No issues in Daz 3 or 4.9.
    Did you install V4 and her bits manually, using the DIM installer, or the Connect system built into the last few D|S versions? Because of the way Generation 4 ExP morphs install and get initialised, they must be installed manually or with DIM, Connect doesn't install the morphs properly so they can be initialised, so they won't work.
  • Did you install V4 and her bits manually, using the DIM installer, or the Connect system built into the last few D|S versions? Because of the way Generation 4 ExP morphs install and get initialised, they must be installed manually or with DIM, Connect doesn't install the morphs properly so they can be initialised, so they won't work.
    I installed the files manually.
