Released: Easy Shape Master - Age Control and Body Tuning for Genesis 8 Females [commercial]
SF-DesignSF-Design Posts: 987
Live now:
https://www.daz3d.com/easy-shape-master-age-control-and-body-tuning-for-genesis-8-female
Do you want to adjust the shape of Genesis 8 Female to make her younger or older? A more muscular or a chubby body shape?
Are you tired of dialing in and adjusting dozens of morphs to get what you want?
This product takes over this work for you by utilizing dozens of the Head- and Body morphs and making the needed adjustments to the character's shape.
Both head- and body morphs are utilized to gain most detail.
You can either use the provided presets for age, body definition and chubbiness or use the provided dials to step less adjust the appearance of the shape and fine tune it to get the shape you like.
The Daz Original Head- and Body Morphs work perfectly with Genesis 8 Female Characters and we take advantage here of this fact by intensively utilizing them.
You can of course use other morphs as well to adjust the shapes even more.
Age dials/presets can be mixed with the body tuning dials/presets (chubbiness/muscularity), so that you can have for instance a girl with strong muscularity or a chubby older lady etc. There are almost endless possibilities to mix and match the controls.
The body tuning options keep active while switching the age presets, so you can see how the actual shaping looks on a young girl, a teen girl or old woman.
This add on works best with the Genesis 8 Female Base Character without any morphs/shapes applied. However the controls work with any Genesis 8 Female based character,
so you can turn V8 into a teen for instance.
You can also make any shape more muscular or chubby in relation to their default shape. Included are also dials and presets for breast shape/size, nipple and navel adjustments to fine tune your shapes. Your settings can be saved as shape presets of course.
Morph Control Dials
  • Younger Shape
  • Older Shape
  • Nipples Adjust
  • Navel Adjust
  • Muscular Shape
  • Chubby Shape
  • Breast Shape Adjusment
  • Breast Adjusment
  • Breast Smoother
Shape Presets
  • Age Presets
    • Preteen Girl
    • Young Teen Girl
    • Mid Teen Girl
    • Older Teen Girl
    • Adult Woman
    • Woman Mid Aged
    • Woman Older
    • Woman Elderly
  • Breast Adjustment Presets for Each Age Preset
  • 7 Muscular Body Definition Presets + 1 Reset
  • 7 Chubby Body Presets + 1 Reset Preset
  • 4 Navel Shape Presets
  • 1 Reset Preset for all controls
Post edited by SF-Design on
«1
  • nicsttnicstt Posts: 11,715
    That elderly woman's face is really good; this looks very interesting.
  • michaeltoomichaeltoo Posts: 221
    I really like the body tuning for a larger woman also adjusting the neck and chin area, not just the body. Other morphs often leave this out, making it look very un-natural. Well  done!
  • SF-DesignSF-Design Posts: 987
    edited July 2017
    Thank you :) Glad you like it.
    Yes, I added adjustments to the chin and face area as well for the chubby shaping. It is more realistic. Shapes like this usually have a double chin etc.
    Oh, as to the elderly woman, I used the OPAL Skin, this suited the shape very nicely.
  • exstarsisexstarsis Posts: 2,128
    Does this include original morphs or is it a collection of highly specific presets for the D-O morph sets gathered under one dial?
    edited July 2017
    It is mainly a collection of dials and presets that combine the DO head and body morphs and utilizes most of them to make it easier to get the wanted shapes with just some dials, like older/younger , breast adjustment etc.
    You will have several dials as listed above and several presets. One morph (breast smoothing) is a custom morph .
    The presets are considered as "suggestions" what I felt a shape looks like at that age. You can of course manually use the dials to get different results and fine tune the shape.
    I decided to utilize the DO morphs since they are working perfect with the G8 figures.
    But this means that the 2 DO morph packs are a requirement.
    These are the dials:
    • Younger Shape
    • Older Shape
    • Nipples Adjust
    • Navel Adjust
    • Muscular Shape
    • Chubby Shape
    • Breast Adjusment
    • Breast Smoother (custom morph)
    and these are the presets (that use the dials)
    Shape Presets
    • Age Presets
      • Preteen Girl
      • Young Teen Girl
      • Mid Teen Girl
      • Older Teen Girl
      • Adult Woman
      • Woman Mid Aged
      • Woman Older
      • Woman Elderly
    OK, cool. Good to know. I'm impressed the DO packages have that much flexibility. Presets constructed by a trained eye are useful!
    edited July 2017
    The DO morph packs are really nice and versatile and you can get much out of them. And most users have them.
    They are really comprehensive , so it really is not needed to create custom morphs again with the same or almost same effect. Only the chest smoothing was needed here as custom morph.  Since it is a lof of dialing and adjusting when using the DO packs to get shape that is younger or older for instance, this add on is also a time saver for those who do not want to dial in 50+ morphs and adjust everything and you have step less dials here then. Just mix the dials, tune the body and save it as preset for later use.
    For G3 I used to create single shaping add ons for different age groups. For G8 I decided to combine all this in one product instead of having 6 products etc.
  • takezo_3001takezo_3001 Posts: 2,026
    edited July 2017
    Outstanding work, looking forward to release! Should also work really well with other body-morph products as yours are based on Daz's morph dials rather than ZBrushed morphs, I really like that idea as it's meant to work with the base character while retaining the flexibility for working with ZBrush-based morph packages as I have ZBrush myself, and buy a lot of ZBrushed-based packages as well!
    Post edited by takezo_3001 on
  • colinmac2colinmac2 Posts: 407
    Looking VERY forward to this. I keep saying G8 needs more morphs.
    edited July 2017
    Thank you for your comment :) Yes, they should work nicely with other body morph products and based characters since these here are based on the DO morphs as you said already.
    Basically everything that works well with the head- and body morphs by Daz will work here fine too. I also tried with V8, works quite good to get a younger or older V8.
    Thank you Colin :) I am sure there will be soon more by other vendors too. I really like the DO morph packs and this was the reason I utilized them here.
  • IceDragonArtIceDragonArt Posts: 12,770
    This looks most useful.  Just because I can do it myself doesn't necessarily meand I want to lol.  This looks like a huge time saver.  Great idea!
    Hehe. Thanks :)Yeah people like you who are familiar with the dials maybe don't want to invest the time. I am curious how the acceptance will be. The separate shape sets for G3 sold quite well. We will see.
    Its not even that I'm not willing to invest the time, but more that I don't have the time to invest lol.  I don't get enough time as it is to do this hobby so stuff that make certain things faster is always a plus in my book.
    Oh yeah. I totally agree. I also like things that make life easier. Not only in 3D :)
    But good news. Qav just finished testing and it is packed up now.
    edited July 2017
    I like time-savers, the issue I have with this, is that one of things I like about the morph dials sold, is that when I start tweaking there aren't a load of 'tweaked' dials already in existence that I have to work through.
    It might be one of those items I buy, see how I manage with it before I decide; we'll see I s'pose.
    I really like your easy teeth - tons of dials, and they can get in the way, but they serve a specific purpose so when I'm doing something else, I can ignore them.
    By utilitsing the main morphs, I'll have to take into consideration that they have a function in addition to what I might be wanting to achieve - if I'm explaining it sufficiently clearly.
    Post edited by nicstt on
    edited July 2017
    Yeah, I understand what you mean. Personally I like to have lots of morphs to tweak and play around to make a character unique, as much as possible.
    Nice to hear that you like my Easy Teeth.
    Here is another promo showing Victoria 8 as a teen girl using the "YOUNGER" dial of Shape Master
    1000 x 1300 - 157K
  • fastbike1fastbike1 Posts: 4,078
    SF-Design "
     Here is another promo showing Victoria 8 as a teen girl using the "YOUNGER" dial of Shape Master"
    That's a pretty convincing teen. Well done!
    fastbike1 said:
    SF-Design "
  • nobody1954nobody1954 Posts: 933
    I have a number of your G3 products. Like them all. This looks like a definite buy.
    Thanks a lot! Glad you like my products and for your support of my work.
    Your nick sounds familar to me , a similar one appeared often on my Rendo sales report :)
    Here on Daz I do not see who actually bought a product.
    edited July 2017
    Well, testing by QAV is finished, product packed up and I think the product will be released shortly :)
  • SigurdSigurd Posts: 1,094
    My cart is waiting with 'bated breath!
    edited July 2017
    Hehe, good to know wink Your cart can be filled soon. It is "ready to release now", and I think they will assign a date shortly.
    Excellent!!!!
    Excellent!!!!
    smiley the release has been scheduled, it will be released within the next week, so stay tuned :)
    it is live now , check it out here
    on sale at the moment
    Sold!!!!!! Thank you.
    I thank you :) Hope you have fun using it laugh
    Hmmm, I was hoping to see some examples of what folks are getting.
