Carrara Challenge #34 - Sing to Me, Muse - WIP Thread
1246712
  • Bunyip02Bunyip02 Posts: 9,288
    Wendy - hope to see some more purrfect renders
    Stezza - Calling Occupants of Interplanetary Craft is my favourite by you so far, with Aunty Jack a close second.
    Headwax - looking forward to seeing the rest of your motley crew
    Diomede - trust you are still going with your landscape, cyclopstritch could do with a few wiggles
    wgdjohn - is your Out of the Woods going to be an entry ?
    Vyusur - a rocky subject tackled with ease by you.
  • VyusurVyusur Posts: 2,235
    Your rocks, er . . . rock! laugh
    Thank you very much!
  • PhilWPhilW Posts: 5,162
    Bunyip02 - with dinosaurs, if you keep the camera low, it will emphasise how big they are (were!).
    Bunyip02 said:
    Dinosaurs "fearfully great reptiles" - from the Flintstones, to Jurassic Park, and Walking with Dinosaurs.
    http://www.imdb.com/title/tt0053502/
    http://www.imdb.com/title/tt0107290/
    http://www.bbcearth.com/walking-with-dinosaurs/
    Dinos!!  this inspires me !!
  • DiomedeDiomede Posts: 15,401
    edited July 2017
    Great progress, folks.  I will circle back to comment after I post another update of my attempt at animation.  Discovered some basics.
    1 - very important that the mesh and bone/skeleton be attached within an animation group, not just a regular group.  That is why I had no tab for NLA clips for the original cyclopstritch.
    2 - Once I fixed the cyclopstritch in a new animation group, I posed the Cyclopstritch and saved NLA clips as poses for left foot planted, right foot forward, right foot planted, left foot forward (repeat start with left planted)
    3 - The animation in (2) creates a run cycle that works on a loop.
    4 - However, I am not successfully saving the animation that combines the poses as a new full animation clip.
    See pose clips saved and then loaded
    Here is one cycle of the resulting run animation.
    bb01 assemble room animation group saved clip poses but how save a full clip.JPG
    1904 x 956 - 225K
    Post edited by Diomede on
    edited July 2017
    You will want to add some up and down movement (usually by moving the hip, or whatever the parent bone is). You're getting there!
    Post edited by PhilW on
    edited July 2017
    wgdjohn said:
    Diomede said:
    It would be great to have an anim catagory each month or perhaps even every other month or so... just my opinion.
    I do have a question though... If I were to create an anmimation could I also use one of it's frames as a 2nd entry or would I need to change it in some way or even have the 2nd entry be something entirely different.
    Hear Ye, Hear Ye -
    The Proconsul for Life (or until August 18th, whichever comes first) rules that a frame from an animation entry may be submitted as a still in either the photoreal or stylized (NPR) categories.
    edited July 2017
    Thanks, I've tried to improve the cyclopstritch animation along the lines you suggest.  Still more to do as per PhilW's recent suggestion.
    I have not abandoned the landscape. I intend to enter the landscape (with a frontiersman) in the photoreal category.
    It might be interesting to compare a low view looking up at the dinos to a high view of a dragon-of-prey circling above the dinos. - if you plan to add dragons.
    edited July 2017
    Excellent rocks, Vyusur.  I always forget about the organic tool.  Those rocks are ideal for replicators with a global gradient shader.
  • HeadwaxHeadwax Posts: 10,452
    Vyusur said:
    head wax said:
    the vertex modeller5 has a little used tool called organic (make organic?)
    to use you draw the shape of your eg rock out with one of those curvy line tools polyline that automatically add verticies
    then hit enter (?) to seal the shape
    then fill polygon
    then use the organic command to buid it up in 3d
    it would work for trees
    make a few then add them together with a boolean
    theb
    use the same method to make a branch - then replicate leaves on  branches then replicate the resuting leafy branch on the tree via it;s shaders
    Complex models can be created very simply by using flat polygons and applying Organic functions to them.
    To create organic models:
    1. Create a closed polyline using the polyline tool and select it.
    2. In the Construct menu, choose the Organic item.
    Thank you very much for description of this modeling technique. Here is the result of my recent experiment with organic tool.
    pleasure, you certainly ran nicely with the ball :) did you use a smidgen of displacement as well?
  • IceDragonArtIceDragonArt Posts: 12,916
    edited July 2017
    Okay I have no idea how to put a video into the forums but my muse is Deep Purple's Smoke on the Water - Fire in the Sky
    It will involve dragons and water and hopefully smoke and fire lol.  No idea how I am going to accomplish what's in my head but I am sure I am going to have fun finding out.
    edited July 2017
    Deep Purple!  Excellent.  So much to draw from.
    On the chance that you might be inspired by "smoke on the water, fire in the sky," one of the best oceans that I have seen was by Fractaldimensia during a previous challenge.
    FD included a screenshot of some of the settings to get his ocean.  He used a terrain in a replicator.  See here.
    https://www.daz3d.com/forums/discussion/comment/405672/#Comment_405672
    thanks Bunyip, your image is looking good, I like the top down perspective, maybe darker shadows would make them sit better and emphasize their size if they were long shadows?
    edited July 2017
    Ice Dragon Art  that's a perfect choice :)
    Diomede thanks for that link
    Post edited by Headwax on
    edited July 2017
    go the jiggle :) have you tried the noise modifier? it can give the impression of wind
    this is one of the first things I did with Carrara so it's pretty rough - but have a look at the umbrella - obviosuly needs smoothing and subdiviison :)
  • wgdjohnwgdjohn Posts: 2,634
    then fill polygon
    theb
    Fell out of my rocker long ago... now you have rocked my world :)
    I hope to get something done before deadline... will post a wip of my firt model effort for a goofy tree.  Hmm... perhaps I should name it Into the Woods. :)
    Thanks for the link!
    edited July 2017
    Due to the size of the scene and also the slope, found it hard to get the best compromise for camera location. This is one that I liked.
    800 x 600 - 1M
    Post edited by Bunyip02 on
  • StezzaStezza Posts: 8,856
    Some more work to do on it yet Bunyip... these dinos are floating... it's a hard job using a scene terrain then getting in close.. personally I don't do that I rather just get a small morphing terrain and duplicate it with different morphs applied to give the impression of size and then the models can be easily posed onto it and shadows applied to give dimension..
    I like where you are going with it yes
    edited July 2017
    My Muse Today....
    The Land of Pug
    clickus for biggus piccius
    Original render
    1200 x 848 - 1M
    800 x 600 - 554K
    Post edited by Stezza on
    Bunyip02, thank you!
    edited July 2017
    Hello Stezza, actually only 2 of the feet were in the air, but the slope was a PITA to position the dinos. Solution - move the sloping terrain to the background and insert a mildly rolling plain for the dinos to stand on. Thanks for the feedback as I was wondering how another pair of eyes would view it !!!!!
    800 x 600 - 922K
    edited July 2017
    theb
    There was not any displacement. I displaced all manually after it was generated by the organic tool. I just recorded a short video on this subject:
    Post edited by Vyusur on
    Thank you, John!
    Bunyip02 - that's working a lot better to my eyes.
    edited July 2017
    Glad you mentioned that.  I know what a standard/regular group is but need to do some research for an animation group.  Gotta get my anim learn on. :)
    Vyusur,  I've just got to add your video for Organic Rock making to my Modeling thread asap... can't help myself.  Great work.
    Post edited by wgdjohn on
    John, thank you a lot!
    As for Deep Purple, my favorite song is «Demon's Eye»
    edited July 2017
    I'm a big fan of Deep Purple too! Jon Lord was one of my keyboard heroes.
