Iray Wont Render
I have tried multiple times but nothing is rendering on my PC, I know I have the latest Iray drivers and everything but nothing is rendering at all. Ive tried changing all the settings in the render settings but nothing has worked. Anyone have any ideas. I am running a GTX 1070
  • Richard HaseltineRichard Haseltine Posts: 111,444
    Are you rendering to CPU or GPU or both? Does it help if you change (Render Settings>Advanced tab)?
  • Are you rendering to CPU or GPU or both? Does it help if you change (Render Settings>Advanced tab)?
    I usually leave it on both, should I only use one or the other??
    Might be worth seeing if it makes a difference to uncheck the GPU (which is most likely to be affected by driver issues)
