Bill Boards plugin for Daz Studio
With the new Bill Boards node plugin  for daz studio,is it possiable to use your own PNG and jpeg images on these billboards.
Geoff
  • Josh DarlingJosh Darling Posts: 143
    Yes, you can add your own. That would make us very happy to see more people using the plugin for custom content, in fact!
    The billboards are square so the easiest thing to do is make your images square as well. You would create a new billboard under the create menu then go into the surfaces pane to add your image. The samples that come with the plugin are set up so there is a diffuse map and an opacity map. Once set up you can save these in a scene or scene subset or you can even save them as Figure/Prop assets.
  • gsm77gsm77 Posts: 23
    Thanks.Great news  This is just as i remember using Bill boards on Bryce years ago when it would work on my Mac . Such a shame Bryce  no longer works on my mac unless i install windows
