A little help here
When I save this happen. What should I do?
  • Richard HaseltineRichard Haseltine Posts: 111,390
    That's saving a thumbnail, so presumably you were saving a sceen or preset? Did you do as it suggested and try again, using a different name?
  • Amazon12Amazon12 Posts: 67
    I can't even save my renders!
    1617 x 917 - 912K
    Where are you trying to save ffrom - the bottom of the render window, or File>Save Last Render? To what folder are you trying to save?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    it could be a permisions thing can you save to another place on your computer?
    I actually get those errors saving to my H drive on occasions, a restart fixes it but it seems to be virtual RAM related from doing a render ironically.
    Tried that. nothing
    I did that, same thing happen
    Can you save a file - of any type - from another application to the same location?
    Under "My Documents"
    How about the first question?
    That I'm not sure.
    Imeant the first question in the reply you quoted - which save command/function are you using?
    I meant the first question in the reply you quoted - which save command/function are you using?
    File -> Save
    OK, so you are saving a scene. Is this a new scene (giving you a file dialogue) or a scene you haev saved before (which won't give a dialogue, assuming you have entered something for author name in Edit>Preferences)?
    A scene I've saved before
    Have yuou tried doing File>Save as>Scene and using a different name?
    Have you tried doing File>Save as>Scene and using a different name?
    Did that too. The same thing happened. I even tried unstalling and re-installing DAZ, nothing.
    Can you save other scenes normally?
    No. I can only save on my thumb drive.
    So you can save to other locations, but not to your Documents folder? Can other applications save to the Documents folder? Can DS save to a different folder in your Documents folder?
    I can't save in any other location.
    edited July 2017
    What ddi you mean by saying you could "only save on my thumb drive."? And can other applications save?
    What did you mean by saying you could "only save on my thumb drive."? And can other applications save?
    Just like I said, I can only save renders on my thumb drive. Every other application on my laptop works fine.
    I'm getting confused again - are you saving renders to the thumbdrive, or are you using File>Save (which saves a scene, not a 2D image)?
    OK, and you can save to the thumbdrive but not to the Documenmts folder? At all, or do you get the .duf file OK just not the PNG thgumbnail?
    OK, and you can save to the thumbdrive but not to the Documenmts folder? At all, or do you get the .duf file OK just not the PNG thumbnail?
    I can save to the thumb drive, but not to the Documents folder and I get the .duf files okay, just not png thumbnail and renders
  • That's odd - and if you render you can't save, using the options at the bottom of the render window or File>Save Last Render? Does saving renders to a diffrent format work? (It wills til try, and I suspect fail, to create a PNG thumbnail if you save the render to a folder in a Render Library but try saving to another location.)
