So i'm guessing there's no way..
denmisundenmisun Posts: 30
edited July 2017 in Daz Studio Discussion
[So i'm guessing there's no way..] to set a keyboard shortcut for non-active-pose pinning? (the soft pin, i.e. right click and click pin translation or rotation). I've checked the customize dialog and see no option for it. Maybe missing something?
any help is appreciated.
    If you click on a body part on a figure (hand, foot, toe, etc.) you should see a tiny thumb tack hovering above and to the right of it.  Clicking this lets you pin the translation or rotation of the selected body part.
  • denmisundenmisun Posts: 30
    Right. Thanks. Unfortunately, I already knew that. What I'm looking for is a method of setting a keyboard shortcut for said menu items.
    Again. sincerely appreciated. Esp from you. I've watched a few your videos in the past :D
  • mikael-aronssonmikael-aronsson Posts: 599
    edited July 2017
    Not sure what you mean, I would think you want to:
    Window/Workspace/Customize (F3)
    Lookup PowerPose/Pin, right click and set shortcut (I use SPACE key).
    But maybe that's not what you are after ?
    Post edited by mikael-aronsson on
  • Fixme12Fixme12 Posts: 589
    edited July 2017
    as far 'm aware of it's not possible to set a hotkey for pinning/lock hand, feet,...., as this is not coded by the devs.
    also the pinning is not actually working well momently certainly not if you would start animate (shaky feet, hip rotation...).
    Post edited by Fixme12 on
  • ben98120000ben98120000 Posts: 469
    Window - Workspace - Customize...under Actions scroll down and expand Inverse Kinematics.
    AWESOME! thanks Ben98120000! And everyone else for your attention on this.
