Why am I getting this weird color bleed around the lips?
Gator
in The Commons
Figures, I think I have my heart set on this color and it's not rendering right. Character's skin is from Avavex, not using the morph. I added LIE Makeup Set 2, the preset Teen or Lips Teen 04 with the same results - this color bleed around the edges of the lips. I even tried saving the PNG from the temp directory out, and setting the Lips and Face to that texture. In the source texture, the edges of the lips have a clean line. I use other colors from the LIE Makeup Set 2 without a problem (preset Punk for example).
What in the wide, wide world of sports is going on, and how do I fix it?
Try looking at render setting>advanced>texture compression, and crank up the thresholds until it stops bleeding. I had this happen once, and that fixed it.
@outrider42
Cool, thanks! That did it. I had to crank it up quite a bit.
Medium Threshold 2048 High Threshold 4096.
Glad I found this. Quite helpful. As newbie as I still am.
I was noticing some color bleed artifacts in some things I was rendering and had no idea how it was happening or why it was happening (imagine that I had to go and check a png first just in case) . I had read another post where someone just changed the High Threshold but that didn't resolve the issue. So changed to the above values and the issue resolved.
Perhaps the default values should be upped for the Daz Studio vanilla state.
Nonetheless these types of forum posts are valuable.
