Uber Volume - Uber Irritation
Okay, so I'm trying to do some volumetric lighting. I have followed the instructions here:
http://www.omnifreaker.com/index.php?title=UberVolume
to the letter. Nothing. I notice that, following these instructions, the 'cone' that is created is at scene center on the floor. Surely one must place this in the vacinity of the spotlight used for the light, yes?
My point is that the instructions do not leave me with a working volumetric light. So what is missing? I also noticed that in the picture there is one panel labled (5), but no instructions refer to that panel. What am i doing wrong here?
Thank you for your help.
GD
Yes, the cone should be parented to the spotlight. Did you have the light selected when you created the cone?
I've just recently started using UberVolume, and I used the same resource as you did to learn how. Like you, I found it somewhat challenging at first... Note that what the webpage calls "SpotLight 1 Volume" might instead by labeled "UberVolume Cone 1" by DAZ Studio. Not sure about the missing #5, but as I recall I just skipped to #6 when I was going through the steps.
Let me know how it works for you with the cone parented to the light.
I found the missing piece:
"In the Scene tab, expand the Spotlight and select Spotlight 1 Volume then, in your Surfaces tab (you do have it open, don’t you?) make sure that Spotlight 1 Volume is also selected. As with any Shader effect, you need to have both the object and it’s material selected, remember"
http://greywulf.net/2009/12/22/when-the-spotlight-falls-the-dance-begins/
I had the volume selected in the scene tab, but not in the shader. It's working now. Thank you.
Glad you got it to work. :) There's a bunch of useful stuff on Greywulf's Lair, but I'd forgotten that he did an UberVolume tutorial...that's good to know!
Just don't place a camera inside the volume so it doesn't crash. I have not heard if this is still the case with DS4.5 but in 3 it was an issue.
It doesn't crash...but with the camera inside the cone/volume you don't get the effect.
thx for confirming that mjc I knew it was an issue in DS3.
I was just playing with it this past weekend...doing this...
So . . . I've gotten these volume lights to work. I am getting these artifacts in my renders. any ideas on the cause? they are never in the same place twice.
Thanks for your input.
Artifacts aside, that's a cool render! :)
What are your render settings, and are you using deep shadow maps, or raytraced shadows on your lights?
Thank you for the compliment. This is a section of my 2nd entry to Stonemason's contest. Anyway, these are my render settings. All lights are set to raytrace.
. . . which brings me to a question: how does (or does it at all) Daz treat intersecting Ubervolumes?
these are my settings:
Two possible areas to be causing them...
Overall shading rate of 1.00 is 'too high' to be considered 'final render' quality. It will sometimes cause 'artifacts' because it doesn't allow enough detail. for animation and what not, it's usually not issue because the motion is going to be the main focus and little things like that, which will only show for a fraction of a second aren't going to be noticeable. But for stills, where there is no motion, they'll be very noticeable...
The other possible area...the Max Steps/Step Size...more steps/smaller size means more/finer details...
Warning: decreasing Shading Rate or step size or increasing the Max Steps will dramatically increase render times.
http://www.daz3d.com/forums/viewreply/274146/
The end result. You were correct, mjc1016. the shading rate made a big difference. this was done at .02.
thank you both for your input.
Wow, is that a typo or was it really 0.02?? No wonder it took 93 hours...!
Amazing result, though! That's an outstanding image, and the volumetric effect looks great.
Edited to add: for reference and comparison, here's a link to adamr001's DS render profiles:
http://www.daz3d.com/forums/discussion/16085/
WOW! That is a fantastic reference. Thank you!
Stuff like volumes tend to need insane shading rates...especially when you think of shading rate as a form of subdivision for pixels...then it makes lots of sense.
I am trying to get a spectral effect with a light beam picked out in dust particles (like the attached photo). I have the volume all set up but I can't seem to get to the right combination of settings to get what I want.
Can anyone give me the settings to achieve this? I tried the ones shown above, but they don't pick out the shaft of light.
Thanks
