Cr2 / PZ2, where can I find the inner parts of these files?
jorge dorlando
Hello,
well I just bought a kinect sensor, and pro brekel face.
everything is installed and working perfectly.
Now, I need to build my own templates, but for that I need to find the internal names to mouth, eyebrows, etc.
brekel a part of the manual says:
In the next column you need to specify the name of the slider in Poser/DAZ to drive.
These can be a bit tricky to figure out since what Poser/DAZ displays in the GUI isn’t always what it uses internally.
A good way to figure these out is to look through an existing .PZ2 or .CR2 file and search for things like “Brow”, “Mouth” or “Lips”.
can someone help?
Opening the CR2 in Wordpad works great not too sure about the PZ2 though sorry and I can't check.
PZ2 files can be opened in a word processor as well.
A plain text editor like Notepad, or the Mac equivalent, would be better in case you accidentally "save" it because word processors like WordPad will add "invisible" settings to the file that can bork it. Editors like Notepad add nothing but the plain text to the file when saved, so would be safer to work with unless you make a copy of a particular cr2 or pz2 before opening it.
Just a thought.
Yeah the reason I suggested Wordpad is that it lays out the text in line order making it eaier to read....Notepad is a nightmare for not breaking up the text.
Plus, Notepad has a size limitation...but the best of both worlds.
Notepad++ http://notepad-plus-plus.org/
Hello all!
Many thanks to both!
solved my problem
thank you very much
Glad you got it sorted out.
Nice suggestion of Notepad ++ there. I keep forgetting about that.
