How Do You Pick Up an Object?
danketchum32danketchum32 Posts: 0
edited July 2017 in Daz Studio Discussion
OK, I undertsand about parenting a prop to the hand of a figure to get it to move with the hand. But what if you want the figure to walk into the scene and pick up the object? Adding a keyframe at a later point in the timeline and parenting seems to affect the object all the way back to the first keyframe at 0. In other words, the object that was suppposed to be sitting there until until it's "picked up" moves anyway. How do I fix this?
Post edited by danketchum32 on
  • Cris PalominoCris Palomino Posts: 12,711
    I can't answer but would be interested in the answer.  However, to make your question clearer, you might change the title of the thread to "pick up an object" so it doesn't sound like a protest. :)
  • Silver DolphinSilver Dolphin Posts: 1,640
    I would use Iclone for this or Blender or Carrara. Daz is not really an Animation program it is more geared to stills. You are talking about complex animation tools some of this has been tackled by Daz user mcasual who has written scripts but I don't think we have strong enough tools in Daz for complex animation. I could be wrong.
    Here are some links
    https://www.daz3d.com/forums/discussion/60291/animate-daz-with-iclone-6-reference-guide#latest
    https://sites.google.com/site/mcasualsdazscripts8/home
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,638
    at best you can render two takes, stopping and unparenting the object at the first frame of the second take.
  • Someone must know the answer to this.
  • Oh well. Thanks guys. I think I'll go with the idea of unparenting the prop and rendering to the point where she touches it. Then I'll parent it and render from the point where she touches it.
    If you turn it as aniblock , I think you can use constrain. (but I do not clear remember, it still work for current genesis figures)
    and mcasuall have made script for such purpose.  (if you hope to make animation with daz timeline, his script help a lot I think)
    https://sites.google.com/site/mcasualsdazscripts/mcjautolimb
    But,, I actually not make such animation with daz timeline,, then just test before about genesis only.cheeky
    blender can easy manage it,, (because it can set keys for constrain)
  • MattymanxMattymanx Posts: 7,000
    Old 3D animation trick I heard about years ago...
    You have two copies of the item in the scene, one is stationary and the other is already parented to the hand
    The one that is stationary is visable until the very moment the character goes to "pick it up".  THe one in the hand is turned off so its not visable
    When you get to that frame, the stationary one and the one parented to the hand should be in teh exact same position.  Then, in that frame when its picked up, the stationary one is turned off and the parented one turned on.
    Then you can have the person do whatever with the item
  • RuphussRuphuss Posts: 2,631
    look at mcasuals scripts
    hes king for this kind of stuff
    still need Casuals Matanim script for visibility
    edited July 2017
    still curious why mcasual can and daz cannot (material animation)
    Post edited by Ruphuss on
    Both Daz and casual have limited resources and have to decide where to apply them.
    for some reason the materials are not keyframable in DAZ studio
    be it actual map changes, values, dffuse etc and visibility, his script adds that function
    Why??? No where in the OP did he mention needing to animate materials.  The instructions are not program specific.
    I understand, what Mattymanx adviced, but I think DS can not set key for node visiblity too. (if I hide, without material setting)
    then to work, May need render each frame, with visiblity on, and off manually setting then render,, I thought (just plan without testing)
    Then I think, how to manage it if I try mantimanx way in daz timeline, to  see it as actuall  animation (withotu manuall on and off)
      I may use scale,  then set key for node,  as zero (to hide), scale 100,  (show) as constant interporation.  on daz timeline .
    (But I just play in my brain only,, feel interesting to learn technic,,,  then I can not say, it should work angel)
    visibility is one of the animatable parameters in the matanim script dialogue
    unless its been added since (not tried truth be told) it was not keyframeable in D|S 4.7 at least, prob last time I tried it.
    edited July 2017
    I do not think it is practially useful,, but I test just from quriosity more,  then if I make  new controller (ERC) for node visiblity,  (I set as pose controller)
    it  can set key for visiblity,,, .^^;  actually it hide, and show,,, with controller key value.
    (I did not expect it work,, because node visiblity could not set key,, but about new parameter can work, and animatable),, so someone use it?
    (I do not know,, why new controller can set key, but default visiblity parameter can not set key,, ds is strange enough)
    Post edited by kitakoredaz on
