help installing Daz 4.9
ToobisToobis Posts: 993
edited July 2017 in The Commons
I installed it using the IM and get this pop up when I open it (1st pic) then in the second pic I get that when I try and login. What does it mean and what should I do please? reinstalling it seemed to do nothing.
Post edited by Toobis on
  • IceDragonArtIceDragonArt Posts: 12,899
    I'm sorry I'm not seeing any pictures?
  • morkmork Posts: 278
    Not seeing any images too, but I guess it has something to do with the content database not working correctly - there are not many things 4.9 will complain about when starting up I think.
    Unfortunately I don't know how to fix it on windows, sorry. But it might get you started.
  • ToobisToobis Posts: 993
    K I figured it out anyway thanks all.
  • GiuMaTaGiuMaTa Posts: 31
    Hello. I had the same problem reinstalling anything into a new PC. In my case the problem was the Bad configuration of CMS.
    I suggest you to check if the CMS Settings are ok.
    It's into preferences (Menu Edit|Preferences) Tab CMS Settings
    The path shoud be: C:\Users\<YourUserName>\AppData\Roaming\DAZ 3D\cms
    You can browser it (If the explorer configuration has show hidden file because the AppData is an hidden directory).
    I hope this is also your problem
    Sorry for my bad English.
    Best Regards
