Seraphim Wings for G8F [commercial]
RawArtRawArt Posts: 6,147
edited July 2017 in The Commons
Seraphim Wings
https://www.daz3d.com/seraphim-wings-for-genesis-8-female
Let your characters soar to new heights with these Angelic wings for your Genesis 8 Female character.
Improving on the popular Seraphim wings for Genesis 3, these new wings for Genesis 8 Female are now Geografted directly onto the body for the most realistic look of any wing set currently in the store. The torso surface area on the wings allows you to copy on ANY material setting seamlessly from any character you wish to use for Genesis 8 Female. A custom “sleeve” figure will hide and blend the seam between any torso material and the wing textures.
Extra bones in the wings now allow for more flexibility for artistic posing while still keeping the structural accuracy of real wings.
Realistically constructed with highly detailed textures suitable for Iray and 3DL
Product includes
One Wing Geograft for Genesis 8 Female
One Wing Sleeve Smart prop to cover torso texture seam
Ten Material presets (Iray and 3Delight)
Bonus Three Fallen Material presets (Iray and 3Delight)
Shaping and movement dials included for easy posing
Also includes IRAY and 3DL MAT files
Post edited by RawArt on
  • RawArtRawArt Posts: 6,147
    edited July 2017
    Many interesting poses and colours
    1000 x 1300 - 328K
    1000 x 1300 - 640K
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited July 2017
    I really like these wings, especially the firey/ember textures. Took me a bit longer to get a render out because I just picked up Anagenessis and was experimenting and having some issues getting the textures to match the geograft (user error, not the product, but if anyone is trying it, the issue I was having is that some NGS surface settings are out of the standard ranges), but I like the end results for the wings and the transition to the skin.
    Seraphim Wings
    3000 x 2000 - 6M
    Post edited by AlmightyQUEST on
    These are gorgeous!
    Nice picture...glad you got the issues worked out.
    I wished there was a way to get a one step solution for the zone that matches the skin, but there are so many different material set-ups out there, the best I could do was make it a seperate zone so that the different sharer setups can be used.
    Glad you figured it out and it was not too difficult :)
  • ConnaticConnatic Posts: 287
    I just got this and the wings are wonderful!  Oddly, there is no documentation whatsoever. I installed with DIM, and looking thru Installed Files I cannot locate anything.  Most aspects were easy to understand, but the extra blending prop is what I am not quite figuring out how to use.
    The documentations "should" read as:
    "After applying the wings to Genesis 8 female, you should then select the wings in the scene tab and then apply the “Seraphim 02Feather Sleeve” figure to the wing.
    Then select you material choices through the Iray or 3Delight folders.
    After you have decided on your Genesis 8 Female material settings you can copy the Torso materials from Genesis 8 to the Torso section of the wings for seamless blending"
    edited June 2018
    I am going to re-install the file, perhaps there was corruption on the installation.
    I discovered that since I was using geo-shell based clothing I was unknowingly getting a geo-shell formed around the wings, also.  My knowledge of geo-shells has increased substantially while making this render.  I thought the bloom setting was causing the ghost-outline of the wings, which I reduced in a paint program.  However, it was the extended geoshell, which I have learned how to make invisible.  I have increased the luminence of the wings' emissions.
    1920 x 800 - 290K
    Post edited by Connatic on
