Studio keeps crashing when I try to open a scene
TheKD
I recently reinstalled OS, and for some stupid reason I decided to download latest studio, instead of sticking with the one I was using before. So I built up a scene with 2 G3F saved and went to bed. Now I am trying to open it, either by double clicking, or by file open it starts to load then crashes.
2017-07-03 18:30:18.823 FATAL: ASSERT failure in QList<T>::operator[]: "index out of range", file C:\Program Files\DAZ 3D\DAZStudio4 SDK\include\QtCore/qlist.h, line 477
What da hell does that mean?
Well, it means that some piece of code tried to access an item from a list and the index of that item is out of range, either it's below zero or >=the number of items in the list, but that does not help you much.
Only DAZ support can tell you what's going on as you would need the source code, and to be honest even that will not help in this case because you need a stack dump of what happend before that to get some information about what is going on.
If you try to load a G3F and save it as something else and try to open it, does the same thing happen again ? a possibility would be that something has been messed up in the installation, but it's strange it works the first time.
It's weird, I got the save from before it to load up, but that lost me about an hours work. The only change that happened between the two saves, was some GOZ tweaks on the hair and clothes to get rid of poke through and cloth hovering inches from skin issues.
