MEC4D's Industrial HDRI pack
2»
  • SimonJMSimonJM Posts: 6,082
    I'm confused ... it was working, with a zip sent to me by Cath,  Now, even with that I have issues!  I suspect this may be a 'local problem' crying
  • MEC4DMEC4D Posts: 5,249
    Well Simon , it is working here and open everything with correct paths no errors
    SimonJM said:
    And now I cannot open the duf file in WinRAR as it tells me is it in 'unknown format or corrupt'!
    edited July 2017
     The Syntax error - expected '{' or '[' actually has nothing to do with it the hdri loaded or not , the error shows always with all HDRI , your error is actually the .duf files not the HDRI files as from your logo looks like the .duf was not loaded completely
    2017-07-03 01:26:54.199 File loaded in 0 min 2.6 sec.
    2017-07-03 01:26:54.215 Loaded file: MEC4D HDRI Abandoned Industrial 1 LOW.duf
    2017-07-03 01:26:54.246 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "D:/DAZ 3D\Studio\My Library\Light Presets\MEC4D\HDRI Abandoned Industrial\Abandoned Industrial 1\MEC4D_Abandoned_Industrial1_4000_2000 Panorama_hdr.hdr", pixel type "Rgb_fp", 4000x2000x1 pixels, 1 miplevel.
    SimonJM said:
    Oh dear - update va DIM has arrived, but upon downlaoding and installing (deleting what I had manually installing first) I go back togetting:
    2017-07-02 14:49:54.018     D:/DAZ 3D/Studio/My Library/Light Presets/MEC4D/HDRI Abandoned Industrial/Abandoned Industrial 1/MEC4D_Abandoned_Industrial1_4000_2000 Panorama_hdr.hdr (1,1): Syntax error - expected '{' or '['
    2017-07-02 14:49:54.020 File loaded in 0 min 0.0 sec.
    2017-07-02 14:49:54.020 Loaded file: mec4d hdri abandoned industrial 1 low.duf
    And the hdr is not, actually, loaded.  Will update the call.
    Post edited by MEC4D on
    edited July 2017
    TIP: When you using HDRI in iray the standard Camera lens setting is Focal Length: 36 mm and Frame Width: 36 mm  for all HDRI, the moment your focal length is higher you need to use DOF, all my HDRI was  shot with F/Stop 11 so that would be the setting for the DOF but of course can be changed if you want to get higher bokeh effect (blur), how higher the value of f/stop under DOF how less the effect of the blur (bokeh effect)
    Iray don't have optical zoom when using HDRI so increasing your focal length to get the object closer will change the camera lens setting and without DOF it will look less natural and all you getting is just fake Digital Zoom resulting in less sharp background that why when using higher focal length and DOF the effect is more pleasant and photographic as with real camera lens with this focal
    example below
    peteVault said:
    Works...no postwork.
    1920 x 1080 - 420K
    1920 x 1080 - 541K
    1920 x 1080 - 293K
    Clean everything , and use fresh again the files are still online download new , my zip is the same as DAZ uodated in DIM
  • peteVaultpeteVault Posts: 308
    edited July 2017
    example below
    Good tips and useful stats on the original parameters...will put them to use...thank you.
    Post edited by peteVault on
  • Lonesome CowboyLonesome Cowboy Posts: 162
    edited December 2017
    My problem is a bit different:
    Only the 1st hdri loads but not the following!
    I am not able to change the hdri. By doubleclicking on an other one this doesn't load.
    It's not the %20%20 problem. The files i have are correct.
    When i hit the "Defaults" button in the render options and reload then an other one of these HDRI this doesn't help. I get an empty scene where the HDRI is not loaded. See attachment.
    I have to change the hdri from hand in the Environment Map
    I have these problems only with this HDRI-Set. Other hdri load without problems.
    1837 x 485 - 321K
    Post edited by Lonesome Cowboy on
