a question about Scuba Diver for Genesis 3 Female(s)
BellaBella Posts: 452
Hello,
I was unsure, is this  https://www.daz3d.com/scuba-diver-for-genesis-3-female-s  only for Aiko7 and the Girl 7?
the description talks about only those 2 figures but the title says Genesis 3....
thanks!
Post edited by Chohole on
    We are querying this for you
  • BellaBella Posts: 452
    Thank you :)
    edited July 2017
    And I have a reply back for you
    The clothing, like all clothing for any of the Genesis figures, works by default on the base figure.
    It looks like it was originally intended as a "toon scuba diver" and probably was released around the time of whichever of those two came out last so was set up favoring them, the toon girls.
    It contains custom fit morphs and prop positioning poses specific for Aiko 7 and the Girl 7. It does appear the 'load everything' presets are set up for those two characters, which would just mean the props are positioned for them.
    Everything would still load onto the base figure and at worse, the regulator position adjusted, which is likely to be required anytime the head is posed anyways.
    Other Genesis 3 Female Characters are supported by auto-follow and the props might require adjustment to be positioned correctly.
    Thank you very much for your help!
