Wrinkles on Skin
Hello,
I am having an issue in my Iray renders that some skin areas appear very "wrinkled" (see screenshots). Is this a specific layer I can edit that will remove this effect? I can't find any information on the subject. Any help will be greatly appreciated.
Thanks!
-JJ
  • EcVh0EcVh0 Posts: 535
    My bet is on the bump map, find the surface that has this kind of wrinkles in the surface tab, scrow down to find the bump map and bump strength and try turn the bump strength lower :) should do the job
  • kaotkblisskaotkbliss Posts: 2,918
    Don't keep them in the water so long ;)
    Thanks that worked a charm!
    You are welcome :)
