Post Your Renders like it's the year 2020!!!
12324262829100
  • stringtheory9stringtheory9 Posts: 411
    edited June 2017
    @stezza, not a bad idea. I was going to make a small library of eyebrow styles for V4 and M4 but no reason I couldn't do the same for the younger lot.
    Post edited by stringtheory9 on
  • StezzaStezza Posts: 8,790
    yes
    Get Together
  • PhilWPhilW Posts: 5,160
    Been clearing out your garage?!
    took a bit of wrangling
    Krampus smiley  hailing for his frappuccino
    640 x 480 - 300K
    1131 x 2000 - 1M
  • VyusurVyusur Posts: 2,235
    Beautiful silver foliage on him.
    the fur is ​modeled, comes with the figure smiley
    used one of the metal shaders in carrara content,  was an anodized one.
    Krampus Tinselpus  tee hee
    You should save him for Christmas,  hang some baubles and fairy lights from his horns,  better than a christmas tree any day.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,222
    are baubles and horns allowed?
    christmas in July? smiley
    edited June 2017
    Post edited by Chohole on
    Mistara - I have been playing with G8F with a view to looking at animations, as part of which I exported the skeleton as a BVH. And the bones in the feet looked very strange, with some toe bones pointing up and being much longer than they should be - this reminded me of the results you were getting on the feet so I thought that I would mention it.  Something is definitely very odd on those feet!
    if they dont fix it, it'll carry over to shoes, the next '8' character, might carry over to g8m
    I've submitted a support ticket on this as it can't be right.
  • DiomedeDiomede Posts: 15,393
    I remember Fenric reporting a problem with the feet of Miki4 and similar Poser "weightmapped" figures for his CR2 plugin.  Wonder if it a similar issue with G8?  (sorry about the use of the term weightmapped, but unfortunately that was the jargon Smith Micro used to distinguish pre- and post- Poser 9 figures).
    Here is the old Fenric stuff to address the Poser 9+ figures.
    http://fenric.com/wordpress/downloads/
    Poser Weightmap Injector (free!)
    This is a .NET 4.0 utility and instructions to help you prepare weight-mapped Poser figures for use in Carrara. This also includes a Poser Pro 2012 Python script that will automatically merge all “old style” rigging zones to weightmaps. This results in far better performance when the figure is imported into Carrara.
  • 3DAGE3DAGE Posts: 3,311
    Saturday funday stuff
    NLA clips : (Three NLA clips for M4) 300frames each
    https://dl.dropboxusercontent.com/u/7907045/In_Fluid_M4.zip
    trying Baby Luna, the ds version
    Smile for the camera
    1280 x 1082 - 2M
    1280 x 900 - 1M
    seems to be a symptom of gamma radiation smiley
    thanks.  would love to have miki3 in rara.
  • magaremotomagaremoto Posts: 1,238
    testing the roughness channels:
    a- mesh only
    b- microdisplacement on
    c- microdisplacement + bumps
    normalization and de-saturation in post
    3600 x 4200 - 713K
    3600 x 4200 - 722K
    3600 x 4200 - 898K
    added micro reflections
    only normalization in post
    2400 x 2800 - 2M
    https://dl.dropboxusercontent.com/u/7907045/SIL_4.zip
    another try at the fluid tank....
    a more continuous motion ,. a little bit more realistic
    Andy - very cool work on these!
    Thanks Phil :)
    it's fun to do.
    The NLA clip should work on any generation 4 figure,.
    Blues Rulz
    early predictor
    w.i.p. lighting setup for The old streets of London
    3600 x 2400 - 2M
    3600 x 2400 - 2M
  • BrianP21361BrianP21361 Posts: 815
    Those look great. I've never had much luck getting that set to look realistic.
    thank you Brian,
    but where or when did you find issues? shaders, lighting or what? maybe I can help
    in my opinion you must act first on shaders since they have been prepared for iray, in carrara they look unrealistic, too dirty and unbalanced
    another shot here with a morning light
    1200 x 800 - 267K
    My renders of the Streets of London just look flat. I've adjusted the shaders by changing highlights, shininess, etc, but they still don't pop like your image. Here's a couple of mine. Any suggestions?
    1500 x 1125 - 2M
    1500 x 1125 - 2M
    here is another couple of shots after normalization in post
    as you can see some textures look darker as if wet with rain, some others seem too dirty or too bright
    about your renders maybe I would increase the light intensity and/or the GI, and would add fake lighting from the horizon line and from the sky (I often use a double ring lamp like in the screenshot below to avoid IL and lower down the sky light)
    3600 x 2400 - 2M
    3600 x 2400 - 5M
    1221 x 719 - 165K
    idl render, different pov of Ana Lucia.   feeling a lil envious of her figure  lol
    2000 x 1630 - 5M
