how to scale the head of G3-female
Dear guys
when I want to make G3's head a little small , then happened as following pictures...
is this function be locked ?
    When you go to shape tab, (or parameter) Actor>head>Real world, is not there "Head propagation scale" controller ?
    it may show what you need. and most safety, can scale head shape.  (I do not remember, this controller is offered in default genesis3 free package, or I bought it,,)
    If unfortunately you do not have the parameter,
     select all children of head node by scene tab,, then go to parameter tab, r-click, set "consolidate proeprties"   (if it not checked).
    do not touch slider,  but  set value carefully with click both side + and -.  or, you can  direct imput value, by click the scale value number.(100% as default)
    it scale all nodes,
    if you try to drug slider at same time, I afraid  you may see jump up value to 100000 or -20000 etc, and hard distortion. (I have not seen this problem before,, but now it happen for me, then if you see same effect, click small gear, then reset,,or restore figure from top menu, . do not be panic please ),
    . if it not work, you can change node setting in joint editor, to force all inherit scale,, but I can not  recommend.
  • kyoreonakyoreona Posts: 213
    it scale all nodes,
    thank u for help
    but I really don't have "head propagation scale " controller
    and the second method , I just do it as your steps, the effect is the same ...as same as the picture I upload..
    crying
    edited June 2017
    I may serch which product include propagation scale head,, but about method2 should work.
    then when you try to scale maulti node at once, did you select all child node of head?
    if you select correctly, when you change scale, you can see curent selection number of parameters.
    in Scene tab, select head node. then r-click scene tab,>select >children
    you may find 78 nodes slected about genesis3female.
    if it not show any number, it means you do not set up parameter tab option, to consolidate property. (I menitoned above)
    and , set  show hidden properties,   ( by r-click parameter tab, then check"show hidden properties" , sorry I forget this option to tell you,, some node scale seems keep hidden, then default not show those scale in parameter, then break face)
    then, click minus and plus like my pic. or click the sclale value, then input number can more presise value for all nodes.
    I believe, I do not tweak set up- for other proeprties, then it should work.
    if you can not see any child nodes (small facial)  in scene tab, r-click tab>show hidden nodes.  then it may show all facial nodes for G3F
    (I feel, if default was not visible,, then you could not select children?")
    this way still safety not cause other problem ,then you can use restore figure, to remove scale.
    unfortunately zero pose not work (because there are some hidden scale properties in face nodes)
    1407 x 828 - 163K
    1250 x 884 - 148K
    1138 x 898 - 150K
    1029 x 897 - 129K
    1125 x 741 - 129K
    1153 x 857 - 145K
    Post edited by kitakoredaz on
    edited June 2017
    Then if you have already installed "genesis3female starter essentials"  correctly,  you must find "head propogation scale morphs", in parameter tab.
    did you select root node, when serch this parameter?
    select root genesis3female, then go to parameter/shape ,  Actor>head>Real world, there should be "Head propagation scale"
    (Btw the file name is SCLPropagatingHead.dsf , then it was packaged in genesis3 starter essential , so we must have this parameter ,without you remove it ^^;)
    thank u !!!
    all your method I already try and they worked !
    yes , the "hidden nodes" is the point ! that's method 2.
    and method 1, I have found the "Head propagation scale" just when I load G3 ,but when I play with it for a while , load some roles that I made into this G3 , the "Head propagation scale" may disappear , so I didn't found it for so long time !
    thank u , the problem is perfect solved !
    yeslaugh
