Can't save to Smart Content
SloshSlosh Posts: 2,391
I have created a few items, some material presets, some are props. I can't seem to get them to show up in the Content DB Editor to classify them and get them to appear in the Smart Content window. Specifically, I created a Genital prop for Genesis from the M4 Genital figure. I have it parented to Genesis, saved it as a Support Asset:Figure/Prop Asset and it shows up in my content library, but when I go to the Content DB Editor, it does not appear. I have made sure to set the Scene Identification and all of the default compatibilities, but no luck.
I know it should work because I did the same thing a few days ago and it worked fine. Unfortunately, I lost that .duf file and started over today and now it won't work. I can use the prop from my content library, but I would rather have it in the Smart Content.
I also have a similar problem with Soto's Flat Top hair. Can't get the hair prop or the materials to show up in the DB Editor.
Any ideas? As you can see in the attached pic, the Male Genitalia.duf shows up, but not the M4toGenesis.duf, which I created.
  • SassanikSassanik Posts: 340
    Did you set up compatibility under the compatibility tab?
    Amy
