Getting Victoria 4.2 AND Michael 4 bases + products to both install/load
I found the base for Victoria 4.2 loads from the content library under the poser formats but it seems like it's a 1 or the other situation after I install Michael 4. If I install Michael 4 first, he will load and work just fine as well as content but this changes if I install Victoria 4.2 afterward. He seems to fall into a black hole and become nothing more than a "does not exist" error message. What's happening and how do I fix this? Ideally, I'd like both model bases and all products to be installed and loading. I've been around forums and haven't had much help. Do I need to manually move certain items after they're installed with install manager? Do I need to have the base's installed to a different path than everything else? If so, what and to where? The only thing somewhat helpful I've come across are instructions to manually download and install the 3 .exe files for the models first, but the .exe files suggested aren't what's coming in the .zip downloads of the product from the site... so I'm not sure where the people who suggested this are getting these magical files or what god's they've appeased to do so... please help. I'm at my wit's end.
  • Richard HaseltineRichard Haseltine Posts: 111,408
    That certainly isn't the expected behaviour. To where are you installing - the default My Daz 3D Library in your Public Documents folder or somewhere else?
