TriAx rigged prop stretch on Rotation
Hi everyone... I'm rigging a prop; and I wanted to make it for Genesis 3 Female figure - that will be able to adopt to the figure's shape and pose well
However, I have serious problem with these objects bending like crazy!
I have used Figure Setup to create a legacy version and compare the two.
First one is custom rigging with TriAx, second one is straight from parametric legacy using figure setup
Both have same values on rotation (I just did one side for TriAx version), and look at how stretchy is TriAx and unstretchy for parametric rigging..
I know I'm must doing something wrong - but don't know where to start.
  • Richard HaseltineRichard Haseltine Posts: 109,221
    That's impossible to answer without knowing how the joints and weight maps are set up.
