Problem Importing Hitman for Freak5
rickfoxxx74331700rickfoxxx74331700 Posts: 186
This is my problem. It happen when I try import Hitman clothes(except glasses) (http://www.daz3d.com/hitman) to Poser Pro 2012 with DSON.
  • Richard HaseltineRichard Haseltine Posts: 108,796
    If you open the Poser file (CR2) in a text editor there should be a call to a Python script, like this
     version
      number 9
     runPythonScript "something.py"
    near the start (possibly with material settings after, but hey don't matter). Is the something.py in the folder with the CR2, and is there a .duf file with the same name too?
  • rickfoxxx74331700rickfoxxx74331700 Posts: 186
     version
      number 9
    I open the files DSON with Poser Library. I don't use Phyton script.
    The duf diles are with py files and crz files in the sam folder.
    Opening the files through the library does use the Python script -the library file runs the .py script and the script launches the importer to read the .duf file. It looks as if they are there - is other content loading correctly with the importer?
    Yes, other DSON works perfect.
