Released: Easy Tongue - Pose Control Extension for Genesis 8 Females [commercial]
SF-DesignSF-Design Posts: 987
Formerly known as "Tongue Controls" since Genesis 1 and for all following generations, now with a new name (as part of our "Easy" product line).
The name has changed but the features are the same :)
I am happy to announce that the version for Genesis 8 Females will be available here on the Daz store soon.
This product is an extension to the default tongue controls of Genesis 8 Female(s).
20 new additional pose control dials give you more control and flexibility over the tongue of Genesis 8 Female based characters.
Make the tongue longer (even extreme long), make it extra floppy or curly, adjust the thickness and width, curve it or adjust it's shape. There are almost endless possibilities. Included are separate controls for the tongue and the tongue tip for most flexibility as possible.
The controls work with any Genesis 8 Female based Characters. They are located in the Pose Control section (Head/Mouth) of the character and for convenience also in the head section.
A versatile product and useful for standard situations and nice for non human creatures as well.
Control Dials
  • Mouth Open Extra Wide
  • Tongue Base Up / Down
  • Tongue Base Left / Right
  • Tongue Base Thickness Adjust
  • Tongue Extra Curly / Floppy
  • Tongue Extra Curved
  • Tongue Extra Length
  • Tongue Extra Thick / Thin
  • Tongue Extra Width (Wide/Small)
  • Tongue Mid Thickness Adjust
  • Tongue Shape Adjust 1
  • Tongue Shape Adjust 2
  • Tongue Shape Adjust 3
  • Tongue Twist
  • Tip Curly / Floppy
  • Tip Left / Right
  • Tip Length
  • Tip Thickness
  • Tip Twist
  • Tip Width
Pose Presets
  • Reset Tongue Controls
Tongue Prep Scripts
  • Prepare Genesis 8 Female Characters
Post edited by SF-Design on
  • pdspds Posts: 593
    Should be rather useful. Is that the default shader for the skin ands tongue? Both look great in your renders.
  • SF-DesignSF-Design Posts: 987
    Thank you :)
    Yes, I used the default base materials with no adjustments.
    some more promos showing the effect of the dials
    1000 x 1300 - 253K
    1000 x 1300 - 279K
    1000 x 1300 - 312K
    1000 x 1300 - 291K
    1000 x 1300 - 303K
    1000 x 1300 - 277K
    The product has passed QAV and will be avialable here on the store soon :)
    Hi folks,
    just to let you know, it is live now in the store and on sale :)
    https://www.daz3d.com/easy-tongue-for-genesis-8-female-s
  • takezo_3001takezo_3001 Posts: 2,023
    This looks great! Outstanding work!
    Thank you wink
  • Was there one for genesis 3? I can't seem to find it if there is.
    edited August 2017
    yes there is one for Genesis 3 M and F , Genesis 2 MF and also Genesis 1.
    But they are not sold here, you will find them on Rendo (same Vendor name).
    I was no PA here at Daz those times so you wont find them here.
    I am not allowed to post store links here to other brokerages, but when you search there or look at my store there you will find them.
  • edited January 2020
    The package installs just fine and there is a duf file to prepare Genesis 8 Female avatar, but the control dials for the tongue do not show up anywhere in the shaping pane.
    Never mind. I had looked in the wrong place, just found the control dials in the posing pane
    Post edited by looplaarz_c032203e76 on
    great. thanks for the update and glad you found the dials.
