DS4Pro - Primitives, or alternatives?
buck415buck415 Posts: 57
Hi everyone.
Poser had (or has) a set of basic primitives such as a cube, a cone, and a sphere that I could load and modify as needed. Now I use DAZ Studio Pro, and want to re-create some basic renders using Genesis. One render involves illustrating the basic sectional planes of the body. The original illustration I created a few years ago with Poser and M4 is attached below.
Does DAZ Studio have a set of primitives, in this example a cube, that I can load and modify to re-create the image attached below?
Might there be alternative solutions to create something very similar?
Thanks,
Buck
  • nobody1954nobody1954 Posts: 933
    edited February 2013
    On the top of the interface, click on "create", then 'new primitives". Your primitives are there.
    Post edited by nobody1954 on
  • buck415buck415 Posts: 57
    Ah, that's perfectly convenient and even intuitive... that's what I get for only looking in the content directory.
    Thank you.
    You are welcome.
  • RarethRareth Posts: 1,462
    Thank you.
    if you have poser on the same machine, you can use whats in the runtime directories as well.
  • wancowwancow Posts: 2,708
    the cool thing about DS primitives is you can make them as high or low poly as you want :)
  • KatteyKattey Posts: 2,899
    For this particular recreation I'd suggest to use squashed cubes. Plane is just one-side surface with no thickness.
    with this caveat, Kattey: you need to know that if you squash it down to 1cm tall, you have to place the cube at a Y position of -1 to have the top be at the ground level.
    Well, I've started to rebuild the images in DS4 Pro and it's already going a thousand times faster than it took me to do the same while using the previous application.
    Thanks again for the guidance, it's greatly appreciated.
    600 x 618 - 148K
