Why does Genesis Generation X2 need to update?
RKane_1RKane_1 Posts: 3,039
What has changed? Have they added functionaility, repaired a function or added Generation 8? I would like to know. Don't know why I am suspicious, just am.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,544
    well since Ralf Sessler D3D passed away its a bit up in the air if any updates will be forthcoming, depends on what his next of kin or any prior partnerships existed.
  • L'AdairL'Adair Posts: 9,479
    I think it's a glitch. I downloaded, but did not install. Then I compared files in the newly downloaded zip with files in the installed zip. The files in the "update" are actually older than the files in the installed version.
  • nDelphinDelphi Posts: 1,934
    The docu site only has this info on updates:
    • 2016-06-08 - updated GenX2 version for future compatibility.
    • 2015-05-22 - 2.0.2 - Fixes problems with some compressed files and with morphs in different libraries, allows to set an output path and has support for V4/M4 G2 shapes (only together with G2 Add-On)
    • 2014-03-19 - 2.0.1 - Corrected crash errors.
    Too late for me, I updated, or i that downdated?
  • RKane_1RKane_1 Posts: 3,039
    edited June 2017
    It's odd since I have updated several times since then and only now it wants to update AFTER the talented and missed Ralf Seesler has passed. I just wish I knew why BEFORE I accepted. Hmmm.
    Post edited by RKane_1 on
  • IceDragonArtIceDragonArt Posts: 12,962
    Uh oh I updated as well.  I hope they do another update to fix the update!
  • Carl FisherCarl Fisher Posts: 135
    Dimension3D had submited the update shortly before passing away, and it hung in limbo for a bit while 'things were sorted out' before going out today.
    Then the update notes were put on the wrong readme....
     2017-06-20 - v2.1.1 Bugfixes:
        formulas were not included for transfers between G2F and G2M
        morphs were not loaded if vertex_count was set to -1
        morphs were not loaded if URL references had different upper/lower case spelling
        possible crash when mixing actor names with and without colon for Poser morph injections
        crash when transferring morph after canceling transfer with properties dialog
    Thanks, Carl. :)
  • wsterdanwsterdan Posts: 3,173
    RKane_1 said:
    Thanks, Carl. :)
    Ditto, much appreciated; like the others, I was worried I'd downgraded... indecision
    -- Walt Sterdan
