Installing content to external hard drive??
joseph06joseph06 Posts: 126
Hi, I am in need of some help. My content library has become really large and started to take up way too much space on my local 100GB hard drive. I uninstalled all of my content as well as Daz and Dim and plan to redownload to my new 1TB portable hard drive. I redownloaded DIM and for some reason it won't let me change the path of install to my hard drive. It wants to put everything under the Public Documents folder and I can't seem to change it.
    You can't change the original but you add a second location & then change the default location to the 2nd location & the original location will no longer be used although it will still be in your drop down list.
  • joseph06joseph06 Posts: 126
    Oh, ok thank you.
  • Richard HaseltineRichard Haseltine Posts: 111,467
    You can remove existing locations if you wish - but you do need to add the new path before you can remove the old.
