Michael 5 Render-Problem (Fatal Error)
yandrisyandris Posts: 93
Hello,
yesterday i installed the Michael 5 for Genesis and after installing content i usualy try out if it works.
First i loaded michael 5, than i changed the face texture to a face with beard and aply the Bump for Close-Up.
After that i would try to render only the face of michael (close-up). But everytime i tryed this there was an error at 98% rendering, and the studio hangs up and did close.
In the log there was an error with the relight. unfortunatly im not at home tu tell you more infos, i will try to render that with Reality2 and LuxRender in the evening. i dont think that my grafic is the problem, my Notebook is an Acer G51J Republic of Gamer. Win 7 Home, all new installed.
Anyone who had/have the same issues?
Thanks for help!
PS: A big praise to all Members of the forum, especialy to the grandfathers of that forum! Everytime i had a question i got a fast and helpful answer. I hope that i could help anybody in the future.
  • TotteTotte Posts: 14,797
    edited February 2013
    The exact errors would be great, also list of other objects, skins etc used and a screenshot if the render settings.
    Also, did you check memory during the render?
    Post edited by Totte on
  • yandrisyandris Posts: 93
    Hello,
    i have the logfile but i can't upload this.
    I have no other objects in the scene, only michael is loaded, no lights no cameras, i just want to render an preview of his face, no settings at this time.
    Rendersettings "Out of the box" on step3 or step4, both the same problem.
    Should i shrink the logfile and post it here? Which part did you need? Also i have the errorlog.xml.
    I unfortunately can't remember the error that appears in the messagebox directly after the crash and i can try it out earliest this evening.
    Thanks
    PS: There are some errors and warnings inside the logfile:
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    - No 3D Mouse used by me, so i think i can ignore this
    Executing startup script...
    DEBUG: Error: Reality cannot find the Add-ons files on disk. Please re-install Reality
    Started in: D:/DAZ 3D/DAZStudio4
    DAZ Studio Started
    - I have the plugin installed, so i don't know whats wrong here, but the Preview-render i would do is not actualy by reality2 plugin.
    0(29) : warning C7050: "_rgb" might be used before being initialized
    Shader Program successfully linked.
    Last entry in logfile:
    Rendering image
    Compiled C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/shaders/brickyard/{c53532df-d42b-421c-a82f-8724ce9a7210}/shader_Surface.sdl...
    Looks like you have several errors in your file, but post the last 30 lines or so. I know for experience that you can get weird crashes in rendering when something else is bad.
    Ok,
    i try to post all since the last start of studio :
    +++++++++++++++ DAZ Studio 4.5.1.56 starting +++++++++++++++++
    Platform bits: 32
    Qt Version: 4.8.3
    Running on Windows 7, Build 7601, Service Pack 1
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
    Cache Line Size = 64
    L2 Associativity = 6
    Cache Size = 256
    Stepping ID = 5
    Model = 14
    Family = 6
    Extended model = 1
    CLFLUSH cache line size = 64
    APIC Physical ID = 7
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    CPL Qualified Debug Store
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 3.9 GB (4283600896)
    Avail: 2.4 GB (2664955904)
    Virtual Memory:
    Total: 3.9 GB (4294836224)
    Avail: 3.8 GB (4106772480)
    Current Memory Usage: 37%
    Current DateTime:
    Loc: Mi 20. Feb 00:41:00 2013
    UTC: Di 19. Feb 23:41:00 2013
    Temp Data:
    Location = C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp
    Disk Total: 74.5 GB (80015519744)
    Disk Avail: 36.9 GB (39675940864)
    Locale: de_DE
    No translator found.
    Reading style definition D:/DAZ 3D/DAZStudio4/resources/style/Darkside.style
    Creating managers
    Reading help index
    Reading help file D:/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file D:/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.7.0
    Supported OpenGL extensions:
    GL_ARB_arrays_of_arrays : NOT INITIALIZED
    GL_ARB_base_instance
    GL_ARB_blend_func_extended
    GL_ARB_clear_buffer_object : NOT INITIALIZED
    GL_ARB_color_buffer_float
    GL_ARB_compatibility
    GL_ARB_compressed_texture_pixel_storage
    GL_ARB_conservative_depth
    GL_ARB_copy_buffer
    GL_ARB_copy_image : NOT INITIALIZED
    GL_ARB_debug_output
    GL_ARB_depth_buffer_float
    GL_ARB_depth_clamp
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_draw_elements_base_vertex
    GL_ARB_draw_instanced
    GL_ARB_ES2_compatibility
    GL_ARB_ES3_compatibility : NOT INITIALIZED
    GL_ARB_explicit_attrib_location
    GL_ARB_explicit_uniform_location : NOT INITIALIZED
    GL_ARB_fragment_coord_conventions
    GL_ARB_fragment_layer_viewport : NOT INITIALIZED
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_no_attachments : NOT INITIALIZED
    GL_ARB_framebuffer_object
    GL_ARB_framebuffer_sRGB
    GL_ARB_geometry_shader4
    GL_ARB_get_program_binary
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_imaging
    GL_ARB_instanced_arrays
    GL_ARB_internalformat_query
    GL_ARB_internalformat_query2 : NOT INITIALIZED
    GL_ARB_invalidate_subdata : NOT INITIALIZED
    GL_ARB_map_buffer_alignment
    GL_ARB_map_buffer_range
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_occlusion_query2
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_program_interface_query : NOT INITIALIZED
    GL_ARB_provoking_vertex
    GL_ARB_robust_buffer_access_behavior : NOT INITIALIZED
    GL_ARB_robustness
    GL_ARB_sampler_objects
    GL_ARB_seamless_cube_map
    GL_ARB_separate_shader_objects
    GL_ARB_shader_bit_encoding
    GL_ARB_shader_objects
    GL_ARB_shader_texture_lod
    GL_ARB_shading_language_100
    GL_ARB_shading_language_420pack
    GL_ARB_shading_language_include
    GL_ARB_shading_language_packing
    GL_ARB_shadow
    GL_ARB_stencil_texturing : NOT INITIALIZED
    GL_ARB_sync
    GL_ARB_texture_border_clamp
    GL_ARB_texture_buffer_object
    GL_ARB_texture_buffer_range : NOT INITIALIZED
    GL_ARB_texture_compression
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_multisample
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_query_levels : NOT INITIALIZED
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_texture_storage
    GL_ARB_texture_storage_multisample : NOT INITIALIZED
    GL_ARB_texture_swizzle
    GL_ARB_texture_view : NOT INITIALIZED
    GL_ARB_timer_query
    GL_ARB_transpose_matrix
    GL_ARB_uniform_buffer_object
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_array_object
    GL_ARB_vertex_attrib_binding : NOT INITIALIZED
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_viewport_array
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_S3_s3tc
    GL_EXT_texture_env_add
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_bindable_uniform
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_Cg_shader
    GL_EXT_depth_bounds_test
    GL_EXT_direct_state_access
    GL_EXT_draw_buffers2
    GL_EXT_draw_instanced
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_multisample
    GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
    GL_EXT_framebuffer_multisample_blit_scaled
    GL_EXT_framebuffer_object
    GL_EXT_framebuffer_sRGB
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_gpu_shader4
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_packed_pixels
    GL_EXT_pixel_buffer_object
    GL_EXT_point_parameters
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_shader_objects
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_array
    GL_EXT_texture_buffer_object
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_compression_latc
    GL_EXT_texture_compression_rgtc
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_format_BGRA8888 : NOT INITIALIZED
    GL_EXT_texture_integer
    GL_EXT_texture_lod : NOT INITIALIZED
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_shared_exponent
    GL_EXT_texture_sRGB
    GL_EXT_texture_sRGB_decode
    GL_EXT_texture_storage : NOT INITIALIZED
    GL_EXT_texture_swizzle
    GL_EXT_texture_type_2_10_10_10_REV : NOT INITIALIZED
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_EXT_vertex_array_bgra
    GL_EXT_import_sync_object : NOT INITIALIZED
    GL_IBM_rasterpos_clip
    GL_IBM_texture_mirrored_repeat
    GL_KHR_debug : NOT INITIALIZED
    GL_KTX_buffer_region
    GL_NV_alpha_test : NOT INITIALIZED
    GL_NV_blend_minmax : NOT INITIALIZED
    GL_NV_blend_square
    GL_NV_complex_primitives : NOT INITIALIZED
    GL_NV_conditional_render
    GL_NV_copy_depth_to_color
    GL_NV_copy_image
    GL_NV_depth_buffer_float
    GL_NV_depth_clamp
    GL_NV_ES1_1_compatibility : NOT INITIALIZED
    GL_NV_explicit_multisample
    GL_NV_fbo_color_attachments : NOT INITIALIZED
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragdepth : NOT INITIALIZED
    GL_NV_fragment_program
    GL_NV_fragment_program_option
    GL_NV_fragment_program2
    GL_NV_framebuffer_multisample_coverage
    GL_NV_geometry_shader4
    GL_NV_gpu_program4
    GL_NV_half_float : NOT INITIALIZED
    GL_NV_light_max_exponent
    GL_NV_multisample_coverage
    GL_NV_multisample_filter_hint
    GL_NV_occlusion_query
    GL_NV_packed_depth_stencil
    GL_NV_parameter_buffer_object
    GL_NV_parameter_buffer_object2
    GL_NV_path_rendering
    GL_NV_pixel_data_range
    GL_NV_point_sprite
    GL_NV_primitive_restart
    GL_NV_register_combiners
    GL_NV_register_combiners2
    GL_NV_shader_buffer_load
    GL_NV_texgen_reflection
    GL_NV_texture_barrier
    GL_NV_texture_compression_vtc
    GL_NV_texture_env_combine4
    GL_NV_texture_expand_normal
    GL_NV_texture_lod_clamp : NOT INITIALIZED
    GL_NV_texture_multisample
    GL_NV_texture_rectangle
    GL_NV_texture_shader
    GL_NV_texture_shader2
    GL_NV_texture_shader3
    GL_NV_transform_feedback
    GL_NV_vertex_array_range
    GL_NV_vertex_array_range2
    GL_NV_vertex_buffer_unified_memory
    GL_NV_vertex_program
    GL_NV_vertex_program1_1
    GL_NV_vertex_program2
    GL_NV_vertex_program2_option
    GL_NV_vertex_program3
    GL_NVX_conditional_render : NOT INITIALIZED
    GL_NVX_gpu_memory_info
    GL_OES_compressed_paletted_texture
    GL_OES_depth24 : NOT INITIALIZED
    GL_OES_depth32 : NOT INITIALIZED
    GL_OES_depth_texture : NOT INITIALIZED
    GL_OES_element_index_uint : NOT INITIALIZED
    GL_OES_fbo_render_mipmap : NOT INITIALIZED
    GL_OES_get_program_binary : NOT INITIALIZED
    GL_OES_mapbuffer : NOT INITIALIZED
    GL_OES_packed_depth_stencil : NOT INITIALIZED
    GL_OES_point_size_array : NOT INITIALIZED
    GL_OES_point_sprite : NOT INITIALIZED
    GL_OES_rgb8_rgba8 : NOT INITIALIZED
    GL_OES_read_format
    GL_OES_standard_derivatives : NOT INITIALIZED
    GL_OES_texture_3D : NOT INITIALIZED
    GL_OES_texture_float : NOT INITIALIZED
    GL_OES_texture_float_linear : NOT INITIALIZED
    GL_OES_texture_half_float : NOT INITIALIZED
    GL_OES_texture_half_float_linear : NOT INITIALIZED
    GL_OES_texture_npot : NOT INITIALIZED
    GL_OES_vertex_array_object : NOT INITIALIZED
    GL_OES_vertex_half_float : NOT INITIALIZED
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_lod
    GL_SGIX_depth_texture
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_EXT_swap_control : NOT INITIALIZED
    WGL_ARB_buffer_region
    WGL_ARB_create_context
    WGL_ARB_create_context_profile
    WGL_ARB_create_context_robustness
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_ARB_pixel_format
    WGL_ARB_pixel_format_float
    WGL_ARB_render_texture
    WGL_ATI_pixel_format_float
    WGL_EXT_create_context_es_profile
    WGL_EXT_create_context_es2_profile
    WGL_EXT_extensions_string
    WGL_EXT_framebuffer_sRGB
    WGL_EXT_pixel_format_packed_float
    WGL_EXT_swap_control_tear
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_float_buffer
    WGL_NV_multisample_coverage
    WGL_NV_render_depth_texture
    WGL_NV_render_texture_rectangle
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: NVIDIA Corporation
    OpenGL renderer: GeForce GTX 260M/PCIe/SSE2
    OpenGL version: 3.3.0
    Maximum number of lights: 8
    Number of auxiliary buffers: 4
    Number of texture units: 4
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 8192 x 8192
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 0
    GLSL version: 3.30 NVIDIA via Cg compiler
    Shadow mapping supported
    VBO supported
    *** Scene Cleared ***
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dbridge.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzassetiofilters.dll
    dzautofit.dll
    dzautoriggerbasic.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcontentdbeditor.dll
    dzcontentlibrarypane.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdelightrenderer.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzmorphloaderpro.dll
    dzobjexporter.dll
    dzoptitexclothbasic.dll
    dzpolygongroupeditortool.dll
    dzprimitives.dll
    dzpropertyeditor.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzrslshadercompiler.dll
    dzsavefilters.dll
    dzscriptedrenderer.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzsmartcontentpane.dll
    dzspotrendertool.dll
    dztextureatlas.dll
    dztransferutility.dll
    dzu3dexporter.dll
    dzweightmapbrush.dll
    dzwinvideo.dll
    sdk_sceneinfopane.dll
    dzmimicbasic.dll
    dzpowerpose.dll
    Reality_2.0.dll
    DEBUG: initDB!
    DEBUG: Db is Open
    Total class factories: 1235
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Fragment info
    Loaded image M5PhillipEyes01Shadow.dsi
    File loaded in 0 min 1.8 sec.
    Loaded file: Michael 5.dsf
    Saved image: C:\Users\Christian\AppData\Roaming\DAZ 3D\Studio4\temp\d2.tif
    Loaded Morph Deltas in 0 min 0.0 sec.
    Loaded file: FBMMichael5.dsf
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbsD.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbsSSS.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs01.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLashes.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs01B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs01S.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLashesO.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbsT.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLashesD.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipEyesO.jpg
    Ran tdlmake on image C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp/d2.tif
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipEyesBS.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipMouth.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipMouthO.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipMouthBS.jpg
    File loaded in 0 min 0.2 sec.
    Loaded file: M5 Phillip All Hairy.duf
    Saved image: C:\Users\Christian\AppData\Roaming\DAZ 3D\Studio4\temp\d29.tif
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorsoD.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorsoSSS.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso01.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso01B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso01S.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorsoT.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFaceSSS.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFaceT.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace01.jpg
    Ran tdlmake on image C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp/d29.tif
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace01B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace01S.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace02B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace02S.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso02B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipFace02.jpg
    File loaded in 0 min 0.0 sec.
    Loaded file: M5 Phillip Face 04.duf
    Saved image: C:\Users\Christian\AppData\Roaming\DAZ 3D\Studio4\temp\d40.tif
    Saved image: C:\Users\Christian\AppData\Roaming\DAZ 3D\Studio4\temp\d41.tif
    Saved image: C:\Users\Christian\AppData\Roaming\DAZ 3D\Studio4\temp\d42.tif
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso02.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipTorso02S.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs02B.jpg
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs02.jpg
    Ran tdlmake on image C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp/d40.tif
    Loaded file: M5 Phillip Bump Close-Up.duf
    Ran tdlmake on image D:/DAZ 3D/My Library/Runtime/Textures/DAZ/Characters/MilMan/M5/M5PhillipLimbs02S.jpg
    Ran tdlmake on image C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp/d42.tif
    Ran tdlmake on image C:/Users/Christian/AppData/Roaming/DAZ 3D/Studio4/temp/d41.tif
    Rendering image
    yandris said:
    Platform bits: 32
    Qt Version: 4.8.3
    CPU Information:
    Can I ask a serious question? Why are you using a 32-bit version of Windows on a 64-bit machine? This won't cause the error by itself, but one thing you really need to realise is that the 32-bit version isn't able to make good use of the memory like the 64-bit version can. You really need to think about changing that as a mere 32-bits isn't making the best use of your system.
    I strongly advise upgrading to the 64-bit version of Daz Studio and retrying. It will save a lot of problems in the long run.
    Post edited by Herald of Fire on
    hello,
    why do i use the 32bit version of Daz Studio? ok i will try to explain why: Because the 64bit version did not have all the plugins that the 32bit version have for free (integrated). For example the LipSync is only available for the 32bit version, and in case i would do an animation i can use lipsync and must not buy the Mimic(Live/Pro) Plugin for lots of money although I can have it for free (lipsync). Ok it is not that powerfull like Mimic, but for me it will be enough. ;-).
    If Mimic would be half that price it is now i would think about it to buy it.
    so far
    ok, an idea, can i install both versions of daz studio? that i have the 32bit and the 64bit version on the same hardware? if so, than i would try it with the 64bit version and map my content to both versions, and if i want to make an animation with lipsync so i can switch to the 32bit version ;-) ?
    Never tried, but it should be possible. I've heard people in the past doing it for similar reasons. You can easily export the animation from 32-bit into 64-bit after it's created to solve any issues. I've yet to find a lip sync program which works with Genesis, so it's not something I get into much. Either way the 64-bit version will probably have an easier time of rendering complex scenes than your current 32-bit one.
  • adamr001adamr001 Posts: 1,322
    What are your advanced render settings? A screenshot of the tab would be ideal.
    @HeraldOfFire
    Ok, i will try to install both Versions and have a look if it works.
    I do not only work with genesis so i will keep lipsync up.
    @adamr001
    The rendersettings were not touched by me at this time, so the settings are "out of the box". But i will post a screenshot this evening, although of the error itself, but im not at home now.
    thanks for help @all
    hello,
    now i can show you the error and my rendersettings.
    I have don 2 screenshots.
    hope that helps ;-)
    thanks
    547 x 522 - 122K
    rendersettings
    334 x 655 - 66K
