A problem with daz content
Hello there!
I've got problem with some daz content (with Aging Morphs 3 as you may look at picture below).  Instead  preview picture of specific content in liblary I see only exclamation point. what does it mean?? How can I fix this problem?? What should I do?? I need some guide to work further...
  • Richard HaseltineRichard Haseltine Posts: 108,758
    You content is not installed correctly/your content diectory paths are not set corerctly. those files are in the Data folder and should not be appearing in the Content Library pane at all, they are accessed behind the scenes when you load the files that use them. Is the content working - do you have sliders for the moprhs? If so then it's just an unneeded content directory. Right-click on the tab of the Content Library pane, selected content Directory manager, expand the current settings to show all the pasts, and post a screen shot here.
