Bryce Pro 7 Space Construction Kit install problem
OK, I've tried a few of the things that I've found in the forums, but none seem to directly apply to what I am doing. I am trying to install Bryce 7 Pro Space Construction Kit. The DIM will not install it, giving me this message. :
- Install Manager cannot find a required path. The package for "Bryce 7.1 Pro - Space Construction Kit" requires that the installed path for "Bryce 7 Pro, 7" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
I also purchase the Bryce Pro 7, downloaded the exe and tried to install that... it doesn't seem to install a program.
I'm obviously doing something wrong here, so if someone could point me in the right direction, I'd much appreciate it.
The application installer is on the Bryce 7 page rather than the Bryce 7 Pro page -- the serial number unlocks the Pro features.
Where is the Bryce 7 page? I can only seem to find the Bryce 7 Pro page.
Daniel - DIM is the Daz Studio Install Manager and it does a great job for Studio, but not for Bryce. Always download the zip. Here is a document that tells you where Bryce belongs and stuff you purchased for it: https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf. You have the Space Construction Kit, the same document is included in the Documents folder.
I'm not finding the actual Bryce application, just the content exe.s.
In your Product Library, Filter "Bryce" (without the quotes) and look for "Bryce 7 Pro". Check this page: https://www.daz3d.com/forums/discussion/176141/bryce-7-pro-executable-missing/p1
