Dare we Specul8
13
    what to do about the glowy nostrils?
  • PhilWPhilW Posts: 5,162
    What renderer are you seeing that in? I thought that was a problem of the past.
    g8f
    on g3m also.
    That's the figure, but not the renderer? Are you seeing this in Daz Studio, Carrara, or a plug-in renderer?
    edited June 2017
    in carrara.
    no epiphanies at moment. mebbe a pizza will help
    i'm using the cellular highlight trick,
    issa killin me to give up on the cellular highlights,
    mebbe can render the cellular to a tiling texture map and darken nostril area?
    in preview her arms are dark, renders okay,  chin scr'tch, something to do with the interactice renderer?
    almost there
    a few more distress messages to go
    1147 x 379 - 164K
    Post edited by Mistara on
    edited June 2017
    Cool work already.
    Could the nostril glow be that you have Ambient Light set to the default (20%). This will produce an unnatural light in the nostrils.
    Post edited by PhilW on
    oops left the ambient default (doh)
    testing out her bending, focused on her shoulders
    i ended up buying the morph expansions and the V8 base >.<
    tried the xolani g3f skin. the 'drunk' expression smiley  inner eyelid not quite right
    1280 x 1786 - 823K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    edited June 2017
    Mistara said:
    Impressive! yes
    Post edited by UnifiedBrain on
    +1!
  • magaremotomagaremoto Posts: 1,238
    great work Mistara as usual yes
    testing G8 and her maps within Carrara (couldn't resist angel)
    normalized in post
    2400 x 3200 - 1M
  • 3DAGE3DAGE Posts: 3,315
    G8 Obj in C8.5
    1280 x 720 - 55K
    w.i.p. G8 maps on G3 Janette; very good maps to play with
    1200 x 1600 - 180K
  • DiomedeDiomede Posts: 15,410
    edited June 2017
    Question -
    - I was able to use Collada dae to export from Studio and load in Carrara.
    - However, the pose from Studio is not applying in the Carrara assemble room
    - even though the figure is correctly posed if I go to the animation tab in the vertex modeling room
    Am I missing a step?
    974 x 1025 - 107K
    1353 x 975 - 160K
    1466 x 999 - 116K
    Post edited by Diomede on
    testing how stable she is with the autofitting.
    https://www.daz3d.com/victoria-8
    Backward Compatibility (Read More)
    Ultimate Content Compatibility (Read More)
    Includes clones for Genesis, Genesis 2, and Genesis 3 content even between male and female figures
    is it more convenient to load the eyelashes separately?   if yoo makin strand lashes.
    or include the lashes in preset?
    heavy sigh victoria 8 eyebrows crashy rara
    victoria's eyebrows, and the eyelashes are following the pose controls, but arent following the morphs. not following the V8 head shape
    basic wear isnt scaling with vicki 8
    If you need strand lashes for Carrara, it should be simple enough to grow them on the mesh, which may be the best way if morphs are proving difficult. Give me a shout if you need some.
    edited June 2017
    yeah  autfit/follow not working.  eyelashes, and victoria8 eyebrows. and clothes, especially in the shoulder area.
    -it looks like the V8FBM isn't included in the basic wear morphs.
    guess could transfer the old fashioned way.
    it doesn't let ya scale a clothes item after it's conformed, or is there a secret way?
    fail - the Victoria 8 morph.
    it looks like a few of the toe nails aren't welded in rara's weld tolerance?
    mebbe a corrective morph to put those badgirl verts where they belong?
    the Victoria 8 body slider has the scaling baked in, when did they start doing that,
    it used to be could use the body shape slider and/or head shape slider,  and only the combo body/head slider included the scaling.
    on the bright side, the fiber eyebrows look pretty decent with antialias set to best.
    V8's pose presets seem to work.
    the add on body,head,expression morphs seem to work.
    the eyelashes and eyebrows follow the face rigging and pose controls.
    1232 x 687 - 123K
    You are making amazing progress, I hope that there hasn't been some new technology that has been introduced under the hood that would scupper your efforts!
  • SileneUKSileneUK Posts: 1,977
    Good going, Misty!! yes   I have family wedding and a lot of dental work coming up, so won't be buying anything new until August...  laughcrying  surpriseSilene
    the flexions are .dsf morphs, i can see them working.
    because the distortion is only the 1 foot,
    mebbe something happened when they applied symmetry to the morph?
    i've tried the V8 morph on both the rigged and unrigged version. (it doesn't happen in DS.)
    i tried removing all the formulaes, it happens with the raw morph.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,561
    good job but I am in no hurry to use G8 as animating her difficult but if you solve it I would buy your character at least heart
    no problems with the foot propagating scale
    1225 x 648 - 172K
    it's these 2 rings of edges.  the V8 morph is scaling her down through the floor.
    should she be scaling up from the floor?
    i can't do anything to tweak her dsf files.
    1202 x 651 - 246K
    Yes, I would as well!!  yes Silene
    welp, the G8 basic wear doesn't have the V8 morph included with it.
    the G3 basic wear included the V7 morph in the basic wear.
    >.<  i just assumed it would be the same for G8. doh
    just tried a Genesis2 dress (Love Potion dress) on G8 and G3, saw the conforming dialog box come up, but dress doesn't bend with the figures.
    the Victoria 8 eyebrows doesn't include any morphs at all.
    I think it's safe to state autofollow and autofit don't work in carrara.  the morphs need to be created in DS and saved before it can work in Carrara.
    there is one bright side, conformed clothes do follow scaling inside carrara.
    632 x 362 - 34K
    i think, the big advancement is the power pose controls?
    she does use the G3 uv template, that's a help. smiley
    edited June 2017
    Thanks smileyheart
    seeing if i can attach her as a beta ...  ...  tee hee,  i've been calling her Veronica Wr8th
    trying attach again:  hold on
    edited July 2017
    Beta for G8F
    ** there is no geometry in these files.
    You need the Genesis 8 Female Starter Essentials installed**
    i'm updating this beta.  be back soon. smiley
    is here  https://www.daz3d.com/forums/discussion/180916/beta-g8f-carrara-preset
