non-symmetical transformations on genesis
TorkudaTorkuda Posts: 148
How on the genesis do you do things like have it tighten one leg muscle and not the other. Or enlarge one arm and not the other?
  • MattymanxMattymanx Posts: 6,997
    You should select the joint (node) to which you want to make the changes to and then go to the Parameters Tab and look under morphs for that node.
  • TorkudaTorkuda Posts: 148
    You mean select a node as opposed to selecting a bone? How does one do that?
    Okay, apparently "node" is another word for bone. Actually the only transformation I see in the parameters section when I selected a "node" is "scale".
  • fixmypcmikefixmypcmike Posts: 19,701
    In the Parameters tab options menu choose "Show Hidden Parameters"
    And that's in the "actor" node BTW. Thanks guys!
