Daz Dragon
My dragons are rendering beautifully in IRAY....except for the eye which remains plain white. Attached is a quick render I did with just a distance light. I don't see a shader or any materials for the eye. What am I doing wrong?
It's the Iray conversion of the defailt 3Delight shader on the EyeSurface material zone that is doing that. Not sure just which texture set you have loaded but teh default dragon I just loaded has that as a omUberSurafce material. Try seletcing the surface and then converting it to Iray glass, thin, clear as a first step.
thanks! I'll give that a shot
